New Tires Rub
Old Jan 24, 2013 | 08:59 AM
loubct's Avatar
loubct
Tires are rubbing due to the width ( 12.5). How is a lift kit going to help . I'm confused.
Old Jan 24, 2013 | 04:21 PM
HammerZ71's Avatar
HammerZ71
Yes - it's the width. '04s are torsion fronts = more room. '06 and newer are coil overs = less room.
Spacers would solve the problem, but I'm also of the camp that would never use them. Yeah, I know LOTS of guys who have them and never had a problem BUT have seen them fail too.
Wheels with 4.25 - 4.5" backspacing would solve the problem - correctly...
Old Jan 24, 2013 | 05:29 PM
loubct's Avatar
loubct
Does anyone know the minimum thickness spacer required for clearance. Its a 2008 1500 SLT 4WD. Tires are 12.5 wide 35 H with 20" wheels. If the required spacer is 1/2 inch or less I would be inclined to go that route
Old Jan 24, 2013 | 09:16 PM
HammerZ71's Avatar
HammerZ71
Have someone cut the wheels while you are in a position to see where/how much they rub. Probably be alright with 1/4" spacers...
Old Jan 25, 2013 | 02:39 PM
Brandon Anderson's Avatar
Brandon Anderson
You didn't specify in your original post. I assumed you were rubbing your wheel well lining.
Old Jan 25, 2013 | 06:48 PM
hyperjay's Avatar
hyperjay
Originally Posted by KasperR34
I ran these same tires (but made by nitto)
I wanted to chime in on spacers:
I've been using 1.5inch adapters on my Ram, with a full lift and 4.5 inch backspaced tires -12 offset. These adapters have survived jumping, high speed off roading, and everything else me as a 17 y/o highschooler put it through.
And to think......... I was driving a 1987 Plymouth Lazer with no reverse when I was 17!!!
Old Feb 3, 2013 | 09:06 PM
mycj7's Avatar
mycj7
Bet ya they are rubbing on the front bumper lower valance. A wheel spacer will not help, might make it worse. Just trim the lower valance a bit.
