New Tires Rub
Old Jan 14, 2013 | 06:28 PM
loubct's Avatar
loubct
Default New Tires Rub
Hi
I have a 2008 Ram 1500 ( Big Horn ) 4 wd. Just purchased Toyo Open Country 35/12.5/20. Town Fair guaranteed me they would not rub. However at full turn there is some rubbing. Would adding wheel spacers 1/4 inch ( or larger) be the easiest solution versus lift kit or offset wheels ?
Old Jan 14, 2013 | 07:20 PM
Blacksport's Avatar
Blacksport
You could try to cut a portion of the wheel liner to prevent rubbing.
Old Jan 21, 2013 | 06:42 PM
1998dieselman's Avatar
1998dieselman
If its only rubbing a little during full turn then don't worry about it- my 35 BFG's rub on my factory 17's on my '05 Hemi on full turn too and it hasn't caused any grief what so ever.
Old Jan 21, 2013 | 09:48 PM
broggyr's Avatar
broggyr
Spacers would definitely be easier, but from what I've seen in the forums, they are not worth it because they are dangerous. I won't use 'em.
Old Jan 22, 2013 | 01:06 AM
dakotatrevor's Avatar
dakotatrevor
Have a look at how close they are to the upper ball joint/control arm...from what I've read anything wider than 11.5 will be rubbing there, all the time.
Old Jan 22, 2013 | 02:05 AM
Radam3's Avatar
Radam3
Not true. I'm running 305's which equate to just over 12, and I have no rubbing what-so-ever
Old Jan 22, 2013 | 08:37 PM
dakotatrevor
That's because, assuming you have an 04 like under your name suggests, you have a completely different front suspension from the OP (his being an 08).
You have torsion bars, he has struts.
Old Jan 22, 2013 | 09:23 PM
Brandon Anderson's Avatar
Brandon Anderson
Easiest, sure. Advisable? Not in the least, especially on a 4x4. I would highly recommend the Bilstein 2" lift struts. Easy to change, looks better than stock ride height and should help your rubbing issue.
Old Jan 23, 2013 | 01:02 AM
KasperR34's Avatar
KasperR34
I ran these same tires (but made by nitto)
I wanted to chime in on spacers:
I've been using 1.5inch adapters on my Ram, with a full lift and 4.5 inch backspaced tires -12 offset. These adapters have survived jumping, high speed off roading, and everything else me as a 17 y/o highschooler put it through.
Old Jan 23, 2013 | 07:29 AM
dirtydog's Avatar
dirtydog
Moderate User
Originally Posted by loubct
Hi
https://dodgeforum.com/forum/3rd-gen...dodge-ram.html
You need a 2" lift/level
