got my build sheet
Old Jan 16, 2013 | 08:15 PM
scwpd's Avatar
scwpd
Default got my build sheet
Well I got my build sheet and was surprised. My truck came with the 17" rims so I thought I had the 3.55 gears wrong it came with the 3.92 the only other this is it has the factory LSD does anyone know of any upgraded c clips or something I can do other that changing to a different LSD to keep it from possibly loosing a clip a destroying my rear end
Old Jan 16, 2013 | 09:39 PM
meyerjrj's Avatar
meyerjrj
Drive the truck and enjoy it! Don't go looking for problems, just do the maintenance and drive it like you care about it. If you beat the hell out of the truck it'll cost you!
Old Jan 17, 2013 | 12:11 AM
08HEMI1500's Avatar
08HEMI1500
I'm going on 4 years with the factory "anti-spin diff" and I haven't had any issues. I've always read that if they do break apart just take em out and keep driving
Old Jan 17, 2013 | 07:52 AM
Izero's Avatar
Izero
You could get 17" wheels with 3.55 gears too.... it should specifically call out which gear set you have in the build sheet.
You can upgrade to an Eaton or Detroit LSD if you have some $ laying around...
Old Jan 17, 2013 | 08:08 PM
scwpd's Avatar
scwpd
If I had the money and a competent shop that could do it I would upgrade. I'm surprised dodge didnt do a recall with all the people that have had problems with the stock LSD well they did but it was just for the 09 & 10 but it is the same LSD
Old Jan 21, 2013 | 08:49 AM
Izero's Avatar
Izero
There are many factors that play into a recall.... basically if the cost of a recall is greater than the cost of paying out lawsuits then they don't do a recall. (That's the simple version so take it at face value.)
Old Jan 21, 2013 | 11:59 AM
JDG103's Avatar
JDG103
ok so how do i get a build sheet
Old Jan 21, 2013 | 12:29 PM
Izero's Avatar
Izero
message DodgeCares on here with your VIN # and e-mail address.
Old Jan 22, 2013 | 08:30 AM
DodgeCares's Avatar
DodgeCares
Yes. Please try and send an outside email address as the PM here is limited in the number of characters I can send so sometimes I have to break it up into 2 PM's. The format is a lot better when sending to an outside address as well.
Old Jan 22, 2013 | 03:51 PM
lxman1's Avatar
lxman1
Site Moderator
Thanks for all of your help here in the forums DodgeCares!!!!
My 08 has 66K on it and no Anti-Spin trouble. Front seal leakage, yes, seal replaced 3 times already. The second time because the spring in the original seal fell back into the housing and ruined the bearings causing a vibration over 60mph when the first tech replaced the leaker and didn't notice the missing spring.
Seal #3 is leaking again, It is a small drip and the fluid is still about full, but it has spotted up my new garage floor. I just haven't had time to run by the dealer and get it replaced again. Might be a bad spot on the yoke. Gota love a lifetime powertrain warranty
Sorry to hijack your thread,
Back on topic, just inspect them at the 60K service. The cover will be off anyway.
