Truck dies after fill up on gas
Old Feb 1, 2013 | 04:36 PM
Willy McNasty's Avatar
Willy McNasty
Recently filled up on gas....did not top off. No problem with truck dying. Yay.
Thanks
Old Feb 1, 2013 | 07:40 PM
dirtydog's Avatar
dirtydog
Moderate User
Thanks
Good deal!
Hopefully it wasnt an isolated incendent..lol
Old Feb 1, 2013 | 07:43 PM
Jareski's Avatar
Jareski
A tip I got from a gas station owner that I know:
Don't top up the pump to an even dollar number, when the pump clicks, hang it up. He said that some pumps will charge you even though most of the fuel isn't getting to your tank.
I dunno how true that is, but he's a good guy, so I trust what he says.
Old Jan 13, 2015 | 10:19 PM
RumbleB's Avatar
RumbleB
Default Same problem
My 2004 Dodge Ram 1500 Rumble Bee has 29k miles on it, After I fill up it dies at the light a few times. My question is can I just replace the EGR valve then? or is it the fuel pump? this thread has me confused slightly
Old Jan 13, 2015 | 10:52 PM
Will_V2Lab's Avatar
Will_V2Lab
My 04 Hemi does this too. When I fill it up at the gas station I call it good after the first time the nozzle shuts off. Haven't had a problem since. I sorta want to get a new fuel pump anyway. I've replaced one on an 03 Ram and it sucks... so I took the bed off.
I was told when I last smogged my Ram that my EGR might be on the way out too. Randomly i'll get a check engine light (every 2 months or so) and it disappears after a few ignition cycles. Truck performance isn't effected by it. Time to research the EGR...
Old Mar 1, 2022 | 07:47 AM
Eric108's Avatar
Eric108
Originally Posted by dirtydog
Common problem for the 2002-2005 trucks has been the fuel pump check valve going bad. Now that 2006-2008's are getting older and higher in mileage it seems we are having the same problems.
Unfortunately, the pump is an entire unit and must be replaced completely. It isnt cheap either! $350 or so.
I would try not filling it up completely and see if it still does it. Then fill it up more and more until it happens. Then you'll know the fill up point. It'll save you money, well, delay the inevitable..lol
Your right about everything except for the $350 fuel pump. Orielly, autozone, and advanced all has them for 200-260 depending on the size of the fuel tank. 26 gal or 33 gal. Or Amazon has it for 60 bucks wich is the route I went a year ago and haven't had a problem with it since.
Old Mar 1, 2022 | 07:51 AM
7 year old thread??
Old Mar 1, 2022 | 07:46 PM
RedRam2002's Avatar
RedRam2002
Actually glad he replied to this old thread, was a good read and good info.
After reading about possibility previously about filling up fully being harder on the fuel pump in an older Ram, I always fill up to just over 3/4 tank since I got the vehicle a couple of years ago.
