2004 dodge ram 1500 hemi 5.7
Old Jan 29, 2013 | 02:58 PM
Nathan Needham's Avatar
Nathan Needham
Exclamation 2004 dodge ram 1500 hemi 5.7
I have a whinning noise all the time with my truck it does not sound like it is the torque converter but i am afraid thats what it might be i am thinking it is a pulley and i have no idea what pulley it is so I am going to put a picture up on here and circle it and let yall tell me what pulley it is and if it could possibly be making the noise i am hearing?
Old Jan 29, 2013 | 03:01 PM
Izero's Avatar
Izero
Check your power steering pump fluid level.. sometimes when it gets low it will whine.
Old Jan 29, 2013 | 03:13 PM
Nathan Needham
Power Steering fluid is good you dont have any Idea what pulley that is i circled in the picture?
Old Jan 29, 2013 | 03:57 PM
Chase Lejeune's Avatar
Chase Lejeune
thats your crankshaft pulley, but on my old 5.9L it sounded like i also had a whining noise coming from the same location. turns out i had lost half the ball bearings in my idler pulley. $30 to replace and that was that. i was surprised the pulley didnt kick the whole belt off and overheat my engine, guess i got lucky.
Old Jan 29, 2013 | 04:41 PM
Izero's Avatar
Izero
the idler pulley is usually the first one to go... but yes that is the crankshaft pulley...I highly doubt that is what is whining.
Old Feb 2, 2013 | 03:42 PM
Wanderer's Avatar
Wanderer
At about 59K, the bearing on the alternator went after I washed the engine without covering it.
Old Feb 3, 2013 | 09:49 PM
p38251's Avatar
p38251
Agree Idler pulley or alt bearing. I had an 04 alt bearing whined the whole time I owned it. Traded it in at 132k still whining. just tell your friends its a super charger. LOL
Old Feb 3, 2013 | 11:09 PM
Chase Lejeune
my idler went after i sprayed it with some penetrating oil. was full of dirt from mudding.
OP, if you're still here, have you solved your problem yet? if not, pull off your belt and spin all of your free-spinning pulleys. idler, tensioner, alt, a/c, power steering? anyway, spin all the pulleys that can spin, and if it doesnt feel right, pull it off and check the bearings.
