!!! My new ride !!! Couple Of Questions
Old Feb 6, 2013 | 10:57 PM
a32ozSlurpee's Avatar
a32ozSlurpee
Default !!! My new ride !!! Couple Of Questions
Whats up guys!
I have been off and on the forum over the years since I got my Dodge 3 years ago.Well I just sold that 1999 Dodge ram 1500 5.2 with 250,000 miles on it. I just got a 05 Dodge ram 1500 5.7 Hemi with 70,000 miles.
Its like day and night compared to my old dodge and I am very pleased....Anyways I have a couple of questions about it.
Just FYI, this does have a aftermarket cam in it. I don't know which one but it just sounds like a dragster
1. First gear does not shift till about 2,300 rpms. Is this normal? Seems rather high when I am not even getting on it.
2. Sometimes when I stop it will drop to 500 rpm and jump up when I stop to about 750rpm. Normal?
3. Do you think maybe it has been programmed to different settings?
Old Feb 7, 2013 | 08:42 AM
Fallguy's Avatar
Fallguy
I have an '05, I will check on the shifting out of first gear in a bit, but I think it is well before 2300 unless I'm still accelerating.
I've never noticed my idle drop.
Old Feb 7, 2013 | 09:02 AM
a32ozSlurpee
Yea on the way to work today it was shifting around 2,300 RPM for sure.
I found a superchip for 200 bucks?? Worth it??
Old Feb 7, 2013 | 10:19 AM
Fallguy's Avatar
Fallguy
Well mine shifted at 2300 as well
Have no idea on the chip, others should chime in shortly
Old Feb 7, 2013 | 10:44 AM
08HEMI1500's Avatar
08HEMI1500
The superchips is worth it as it allows you adjust shift points and idle plus many other features. Google superchips.
Old Feb 7, 2013 | 12:19 PM
Izero's Avatar
Izero
Originally Posted by a32ozSlurpee
Whats up guys!
Sounds like you've got a custom tune in there to accommodate for the Cam and w/e else has been done... If I was you I would be trying to find the previous owner and see if he can help... or start contacting shops near you that do custom tunes on trucks.. they might have done yours and might be able to dig up a build sheet or some kind of info on it...
Also sounds like you have a high stall Torque Converter.. so I am guessing that it prolly has some other transmission and possibly motor work done to it...
Good Luck Man, Looks Like a great truck
If it DOES have a custom tune on it any kind of programmer could really screw it up...
Old Feb 7, 2013 | 12:24 PM
V10Rampower's Avatar
V10Rampower
mine idles at 500 all the time? i dont know why It would jump up to 700
Old Feb 7, 2013 | 02:05 PM
itsUhHemi's Avatar
itsUhHemi
Maybe your A/C is kicking on and causing it to jump up in RPM's. I'm not sure if Dodge's do that but that could be a reason I guess.
Old Feb 8, 2013 | 10:24 PM
a32ozSlurpee
Well I think I will film a video tomorrow to show what I am talking..
Also tonight I was hearing a squeaking when I was driving but when I left off the gas it would stop. Also it quit after I drove it for alittle bit.... U joints?
Old Feb 10, 2013 | 12:38 AM
itsUhHemi's Avatar
itsUhHemi
I just had to replace my U-Joints a couple months ago when I got my new truck. They would squeak when I first start accelerating then it would stop once I got up to about 20-30 MPH. Best way to figure out is to have somebody listen while you slowly accelerate (2-3mph). It cost me about $33 bucks for two U-Joints then I took my drive shaft to a local mechanic who replaced them for another $20 because I was having trouble getting them apart.
