So the other day I decided to check out what my plugs looked like and when I pulled No. 1 I was suprised to see no node at all. It was completely flush and slightly pitted into the ceramic. I have 150,000 on my '04 which I purchased 3 years ago. I have no idea if the plugs have ever been changed. I am gussing no because the rear plug on the driver side needed some PB Blaster to get it out. Took me about an hour and a half to get everything done. Hopefully this will help my 12.6 MPG and bump it up to at least 13.5 to 14. I also recently dropped in a cold air intake so with the plugs and CA, I am expecting to see results. If anyone wants to comment please do so.
The time is about average. It usually takes 2-3 hours to change out the plugs on a 5.7L (don't know which engine you have). Hope you replaced with the stock plugs as that's what these engines seem to like. As for an MPG bump, I wouldn't expect to see much over .5.
Truck has a 4.7L in it. According to Advance Auto, it states that the Motorcraft plugs come from the factory, but I beleive that may be false as during my readings, the Champions seem to be the plug of chioce from the factory. I went with the Motorcraft's as they got good readings...
We will see over the next few weeks..I will keep you all posted.
I have run across a few Rams that when you don't use the champions (OEM) you may end up with a funny idle or a check engine light! Hopefully you will see 14, my buddy has an 06 Ram and after a good tuneup and a CA and cleaning the injection system he averages 15
As I keep reading I am amazed at how these engines are so finiky when it comes to the plugs. So based off lxman1 statement, the plugs that I pulled out were the OEM plugs from the factory. I had some what of a bad idle prior, but that was most likely caused by the plugs never being changed. I am anxious to see how everything goes. If these Motorcraft's don't do the job then I will change out for Champion's. I hope that's not the case though.
Tranny flush is next....
Do NOT trust AAP when it comes to that stuff. When I was changing my plugs I went there to get plugs first and the guy said my truck came with Iridiums from the factory. I told him he and his computer were wrong and took my business to Autozone where their info was correct and said the Champions were stock.Originally Posted by racerxv6
Truck has a 4.7L in it. According to Advance Auto, it states that the Motorcraft plugs come from the factory, but I beleive that may be false as during my readings, the Champions seem to be the plug of chioce from the factory. I went with the Motorcraft's as they got good readings... We will see over the next few weeks..I will keep you all posted.
You should also consider the NGK plugs. I put the expensive E3 plugs before knowing much about these engines and had a rough idle following install. I did some searching and decided to go with the NGK V-Power plugs and they smoothed the idle out. As for mpg increase none noticed.
Ok, well I am into week one and I believe the Motorcraft plugs are doing just fine. mpg's seem to be up around .3-.5 according to the computer. I am going to do a manual check after my next fillup to be sure and get a better reading. As for the plugs themselves performance wise. I ahve not expeirenced any rough idling or anything of that nature. One thing I do still expeirence is a drop in idle for about .5-1 seconfd. This truck has done this since I purchased it 3 years ago. Has anyone come across this before with their truck? I have a 4.7L in it.
Thanks,
Matt
Thanks,
Matt
