Fuse vs Fusable Link?
Old Mar 9, 2013 | 08:31 PM
skiahh's Avatar
skiahh
Default Fuse vs Fusable Link?
I plugged a a borrowed trailer into my 7 pin adapter last week and all looked just fine. Lights worked (except for the bright element of the rear left light) and everything looked good. Before I started to move, I tested the brake controller and nada. I was in next door to a trailer repair shop, so asked him to quickly test the circuits and all looked good with the truck; just a blown trailer brake fuse (link?).
I replaced it and it immediately blew again. I do remember hearing an electrical zzt kinda noise when I plugged the trailer in, but thought I was just being slow in pushing it together.
At the parts store today, I had the choice of a 40A fuse or fusible link. Of course, I didn't have the blown one with me, but based on color (a lighter shade of green), I went with the link. Haven't put it in yet, so I can go swap it out.
Does it matter? I understand the basic difference between them, but just basic. I looked in the service manual, but can't find a spec that lists one over the other.
Thanks for the help!
Old Mar 9, 2013 | 08:41 PM
crazzywolfie's Avatar
crazzywolfie
what does the lid of the fuse panel say should be there. you should never install a fuse with a higher amperage rating than what is suppose to be there. how many wheels is there on the the trailer? sounds like there might have been a short in the wiring or something.
should almost have the brakes on a self resetting circuit breaker so you have brakes when you need them
Old Mar 9, 2013 | 08:43 PM
skiahh's Avatar
skiahh
No, not going with higher amperage; that's a no-no. 40A is the correct size, I'm just not sure if I need a fuse or a fusible link or if it doesn't matter.
I think the short is in the trailer wiring and I'll tell the owner. I just need to put the right fuse/fusible link back in my truck.
Old Mar 9, 2013 | 09:13 PM
crazzywolfie
the diagrams i have access to suck. what color was the original fuse. the fuses usually go by color.
Old Mar 9, 2013 | 10:08 PM
skiahh's Avatar
skiahh
It's green.
The 40A fuses/links at the parts store were various shades of green. All very close. Helpful, huh?
Old Mar 9, 2013 | 11:01 PM
crazzywolfie
i guess if all the green fuses were 40 then it would be a 40 amp fuse that you need. otherwise i would just trust what the lid on the fuse panels says.
Old Mar 10, 2013 | 12:08 AM
skiahh's Avatar
skiahh
OK, I guess I'm not being clear.
I know I need a 40A fuse or fusible link.
My questions is, what is the difference between the two and does it make a difference if I get one over the other?
Fuse...?
Fusible Link...?
Old Mar 10, 2013 | 07:00 AM
SupraRam's Avatar
SupraRam
Fuses are meant to blow immediately upon over current. A fuse link is more tolerable to this situation and will blow "slower". That is the only difference. I personally would stick with OEM and a standard fuse.
