how to disconnect MDS on 08 Ram???
Old Apr 14, 2013 | 02:00 PM
mextexdodge's Avatar
mextexdodge
oh wow 22 mpg driving fast awesome than image if you drive it steady probably increase mpg
Old Apr 14, 2013 | 05:08 PM
Got_Mitch's Avatar
Got_Mitch
This might sound weird, but I Love my drone sound. I like turning the music down and turning the drone on and off the the throttle.
Old Apr 14, 2013 | 05:45 PM
hemi4109's Avatar
hemi4109
Originally Posted by MikeHTally
It isn't that helpful for the Ram. That's a big face to push through the air, plus the Ram is pretty heavy. Folks who have done exhaust mods sometimes find the "drone" produced when the engine shuts down the four cylinders to be annoying. .
My old man traded an non-mds ram for the new model year when they came out with it (end of lease) and with the exact same truck, tires, 4x4 and driving habbits, he saw about 2mpg more on the highway. He actually saw the biggest gains coasting back in forth in traffic after work on secondary roads when it kicked in quite a bit. Might not seem like much but if getting anywhere from 10-20% more, probably adds up to $500+ a year for many.
Old Apr 14, 2013 | 07:01 PM
08HEMI1500's Avatar
08HEMI1500
To be honest I saw no gain or loss in city driving with or without MDS and a slight gain on the highway with it turned off. So the system in my mind is junk and the fact that it doesn't provide consistent gains for everyone adds to its unreliability
Old Apr 14, 2013 | 08:48 PM
hemi4109's Avatar
hemi4109
I can see where it wouldn't work all that well on lifted trucks with larger tires. You'd need more than 1/2 an engine to power it down the highway.
Old Apr 15, 2013 | 08:04 PM
MikeHTally's Avatar
MikeHTally
Who said 70 mph is fast? I usually run around 80 on the interstate.
Old Apr 15, 2013 | 08:39 PM
08HEMI1500's Avatar
08HEMI1500
70 is my average highway speed that yields me good time and mpg. 75 is the fastest I go in order to make it home on one tank
Old Apr 15, 2013 | 08:40 PM
08HEMI1500's Avatar
08HEMI1500
Yea I only had MDS shortly after the lift and tires went on. Maybe about 5 months. Then I got my tuner and shut it off and saw gains on the highway only. City was still the same.
Old Apr 16, 2013 | 06:38 PM
lxman1's Avatar
lxman1
Site Moderator
5w-30 is too thick for the MDS solenoids and has been proven to damage them over time.
The tach will jump 300rpm when the MDS kicks it. The PCM partially unlocks the torque converter when in 4cyl mode.
As mentioned, you can drive in tow/haul mode which, along with disabling the MDS, also raises the 2-3 and 3-4 shift points and locks out 5th gears. A tuner such as Diablosport or Superchips will also let you turn it off.
It does increase mpg at about 60mph or less, above that, the wind resistance is too much for it too stay engaged long enough to do any good.
