A/C problems
Old May 21, 2013 | 09:32 PM
hitmand850's Avatar
hitmand850
Unhappy A/C problems
My a/c randomly stopped blowing cold air. The first time it was the blend door (fixed) then it was the wiring to the blower motor now IDK. Freon levels are good, compressor kicks on, blower motor running, I cant figure anything else to check w/o tking it to a shop and pay crazy money for something probably minor! Any ideas
Old May 21, 2013 | 09:37 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Have you checked your a/c condenser fan to make sure it's running all the time?
Old May 22, 2013 | 11:59 AM
BigSloth's Avatar
BigSloth
How did you check the refrigerant pressure? What was the static pressure, high/low side pressure?
Old May 22, 2013 | 12:31 PM
The_Penguin's Avatar
The_Penguin
similar thing happened to me - turned out to be the temperature sensor that is in the evaporator coil was bad.
Old May 22, 2013 | 04:47 PM
lxman1's Avatar
lxman1
Site Moderator
The condensor fan is a common issue.
Old May 22, 2013 | 05:31 PM
hitmand850's Avatar
hitmand850
Yes the condenser fan is running
Old May 22, 2013 | 05:42 PM
hitmand850's Avatar
hitmand850
I took it to a shop today to get 1 of the free checks and the guy tells me my compressor is working just not correctly so he wants to change my whole compressor, orifice, etc... NO SIR!
Old May 22, 2013 | 05:50 PM
dodge dude94
Usually, the compressor either works, or it doesn't. You've got something else going on here.
Old May 22, 2013 | 06:49 PM
colbyj1986's Avatar
colbyj1986
I'm guessing your lines are freezing. How did u check your pressures.
Old May 22, 2013 | 08:34 PM
BigSloth's Avatar
BigSloth
Not true. A compressor works like an engine, it has pistons that pump the refrigerant. Over time they can wear out and the performance of the unit will drop until it can no longer sustain the load of the system.
But the sudden stop of cooling in this situation says that's not the case here. It's probably sensor related.
