I need help replacing my mirror (glass)
Old Jun 5, 2013 | 06:05 PM
risher2909's Avatar
risher2909
Default I need help replacing my mirror (glass)
I cant seem to get the glass off of the housing. I have a 2009 ram 1500. The mirror is powered and heated.
suggestions please!!
Old Jun 5, 2013 | 10:10 PM
Not sure if you can just replace the glass.... check the third gen ram section for suggestions.
Welcome to DF!
Old Jun 6, 2013 | 01:10 PM
Welcome to DF! Post your question in the 3rd gen Ram section. They will help you out.
Old Jun 8, 2013 | 12:39 PM
Wanderer's Avatar
Wanderer
Give this a try, from the 2004 service manual. Good Luck.
REMOVAL
Standard Mirror
(1) Position the mirror glass so that it’s facing in
toward the vehicle as far as possible.
(2) Disengage the rear housing cover retaining
tabs and remove the cover.
(3) Disengage the lower glass retaining tab to
motor.
(4) Slide glass up and remove from motor.
(5) Disconnect the two heated mirror electrical
connectors, if equipped.
Tow Package Mirror
(1) Position the mirror in the out position.
(2) Release the retaining clip and separate the
glass.
(3) Disconnect the four heated glass electrical connectors,
if equipped.
INSTALLATION
Standard Mirror
(1) Connect the two heated mirror electrical connectors,
if equipped.
(2) Position the mirror glass mounting holes over
the four feet of the mirror motor and slide down.
(3) Engage the lower glass retaining tab to the
motor.
(4) Position the rear housing cover and seat the
retaining tabs fully.
