Low oil pressure at idle
Old Jun 11, 2013 | 11:19 PM
Greasy24's Avatar
Greasy24
Default Low oil pressure at idle
I have just started having oil pressure problem I changed out the sensor and put a mech gauge on it. No pressure at idle once warm but no ticking or knocking. Motor was just rebuilt with new crank and bored pistons about 20, 000 miles ago.is it the rod bearings or crank or could it be something else.
Old Jun 11, 2013 | 11:23 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Pull the pan and see if the pump is clogged. Could be that whatever crap that is sitting in the pan could be getting pulled up into the pump once said crap is heated up.
Old Jun 11, 2013 | 11:25 PM
Greasy24's Avatar
Greasy24
This all started after some bad mixed gas and diesel was accidently put in the tank and was raising the oil level. Now the gas is gone and the oil is fine but the no oil pressure started.
Old Jun 11, 2013 | 11:26 PM
dodge dude94
Gas is a solvent. So it could have released crap built up in the engine somewhere.I know it was just rebuilt, but pulling the pan to check the oil pump is the first step at this point.
Old Jun 11, 2013 | 11:27 PM
Greasy24's Avatar
Greasy24
Sorry and I just pulled the pan replaced the oil pump and cleaned the extra silicone I used when rebbuilding the engine. It did have about half of the oil sump with the dry stuff the engine knocked loose.
Old Jun 11, 2013 | 11:30 PM
dodge dude94
So you've already pulled the pan and it is still reading zero pressure? New pump or original?
Old Jun 11, 2013 | 11:32 PM
Greasy24's Avatar
Greasy24
I think that's everything I have done so far sorry I forgot about that, I just finished rebuilding the tranny and did it while the tranny was pulled
Greasy24's Avatar
Greasy24
New pump.
Old Jun 12, 2013 | 07:54 AM
Greasy24's Avatar
Greasy24
Drove to work, on cold start up 45-65 psi oil pressure when it was up to temp 25-35 psi, and after driving for a while 15-25 psi driving and if the gauge is right 0 at stop lights?
Old Jun 19, 2013 | 01:24 PM
Greasy24's Avatar
Greasy24
Pulled pan off again checked crank and rod bearings the crank bearings where not wearing properly so new bearings. Fixed oil pressure but whats normal idle pressure for my 5.9?
