A/C issue
Old Jun 12, 2013 | 10:26 PM
jojo4711's Avatar
jojo4711
Default A/C issue
I just bought a 2003 4.7 standard cab and the A/C blows cold and feels great, but only when its on high. If its on anything but high it does not blow at all. I;m thinking electrical problem behind the controls, any other ideas of what it could be?
Old Jun 12, 2013 | 10:33 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Blower resistor is blown:
http://www.rockauto.com/catalog/more...596&cc=1413414
That guy.
My dad's had the same problem, junk got onto the heatsink and made it over heat and bust the solder point on it. I cleaned it up (as well as the HVAC box) and resoldered the point, then put it back in.
Old Jun 12, 2013 | 11:03 PM
jojo4711's Avatar
jojo4711
So what do I have to do in order to replace this part? Where is it located?
Old Jun 12, 2013 | 11:40 PM
dodge dude94
Under the passenger side of the dash, you will see two plugs: one goes to the blower, the other to a little rectangular thing up in the HVAC box. That plugs into the blower resistor. Unplug it, take out the two screws and remove the resistor. There will likely be a rain of crap from the HVAC box. If there is, shop vac as much of the crap out as possible and scrape it out with your hand (it's nasty, but necessary to clean it out). You might be able to repair the resistor if the solder point is broken where the little bar goes across the three pin things between the heatsink block and the base. If that's the case, just solder it back on. If that's not it, buy a new resistor.
I did a bunch of research on this when my dad's blew, and your symptoms are the EXACT same as all that I've found previously.
Old Jun 13, 2013 | 12:31 AM
rhino405's Avatar
rhino405
Default ac vent problems
i have 2002 ram1500 and the ac blows fine and cold except itonly blows out of defrost and floor vents so i went n bought new ac cluster panel n that didnt work now im stuck also will the ac parts on a 2007 fit my 2002
Old Jun 13, 2013 | 12:35 AM
dodge dude94
Blowing only out the defroster and floor vents on acceleration or just all the time?
Only on acceleration is "wild vents", all the time is a broken blend door in the HVAC box.
I suggest you to start a new thread.
Old Jun 13, 2013 | 12:44 AM
rhino405's Avatar
rhino405
wont let me start new thread and how do i go about fixing blend door and will the 2007 parts go on the 02
Old Jun 13, 2013 | 02:35 AM
dodge dude94
That depends on how badly the blend door is fubar'd. Sometimes it needs a little cam to be replaced, other times the entire door is fubar, won't know without actually taking it apart/doing more looking.
And if the HVAC system is the same between the two, I don't see why not. But don't quote me on it.
Old Jun 13, 2013 | 02:41 AM
abarmby's Avatar
abarmby
Rhino405.
Go to this web site.
http://www.heatertreater.net/?gclid=CMuK67q34LcCFYTJtAodhggA3w
On that site, put in your make and model and there are videos to both diagnose and repair all the Dodge AC and heater doors. With links to parts to buy from them to do it.
Hope this helps?
Al.
