Weak Factory shock mount fix
Old Jun 12, 2013 | 11:00 PM
KasperR34's Avatar
KasperR34
Default Weak Factory shock mount fix
In case you're new or forgot, this is what happened to my shock:
and now, puns:
When I saw this I was shocked
You can say this was shocking
It was a shock
It became quite the shocker
This was shocking news
It took me a while to absorb the shock
This is not absorbing any of my shock
This did not dampen the shock of the discovery
and now to the new post:
Okay, so today I chopped off the existing broken mount with a hammer, gasket scraper, breaker bar, flat head, larger hammer, dye grinder, and sawz-all. Luckily I had enough motivation to do the other side, lol
So until Friday when I get them welded on, I have no front shocks
The new mounts are 1/2" plate with I believe 1/4" sides.
Old Jun 13, 2013 | 10:17 AM
guitman32's Avatar
guitman32
Handled like the captain of the zombie response team...well done sir.
All I want to know is how many zombies you ran over for this to happen?!>
Old Jun 13, 2013 | 01:30 PM
ewing111's Avatar
ewing111
sweet upgrade, i like it.
Old Jun 13, 2013 | 01:55 PM
Izero's Avatar
Izero
don't forget to mock up again before you permanently weld it in place....
Cool Upgrade to those weak mounts though.
Can't wait to see the finished product.
Old Jun 13, 2013 | 07:14 PM
KasperR34's Avatar
KasperR34
Thanks guys!
Izero, it's nice to see you actually like my work for once, lol
Another reason you should all change those mounts:
In that circled area, the factory mount basically is just a pocket, it holds water and is what I assume to be untreated metal frame. When I cut those sections out (Very simple, cut down the welds and hammer it off with a wedge like object) they were flaking with rust. I should have taken pictures, but I reacted quickly and ground it all away
So basically your factory mounts are raising rust and that will eventually rot through that section of the frame
Last edited by KasperR34; Jun 13, 2013 at 07:15 PM. Reason: Because Racecar spelled backward is still racecaR.
Old Jun 13, 2013 | 09:20 PM
KasperR34's Avatar
KasperR34
and now, more free information
3.5" wide
4" top length 1/2" hole
7" corner to corner
5" tall
15-25° angle. Be creative
Old Jun 14, 2013 | 09:52 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Very nicely done. You must have some really bad roads around you though. Those things were really deformed! I'm sure the rust helped though
Old Jun 14, 2013 | 10:39 AM
Izero's Avatar
Izero
Originally Posted by KasperR34
Thanks guys!
Yeah well this one won't kill anyone... hahahaha
Can't wait to see the finished product...
Old Jun 16, 2013 | 10:09 PM
KasperR34's Avatar
KasperR34
My welder challenged me and said I can't break them. So far, he's right lol
Old Jun 17, 2013 | 11:05 AM
kx250frider617's Avatar
kx250frider617
You might want to fix your passenger side CV axle boot. It looks like you do alot of offroading so check and see if its not already worn out from dirt.
