truck jumps when going from park to drive
Old 06-27-2013, 07:55 AM
drewactual's Avatar
drewactual
drewactual is offline
Originally Posted by swamper
I checked the tranny fluid its not low at all.but the guy who i bought the truck from over filled it by about half a quart.guess its not the fluid then?
If you are experiencing 'drain back' from your t/c, it pretty much doesn't matter where the fluid level is at.. Overfilling the trans is just as bad as under-filling it can be.. let's hope you haven't pushed a seal out somewhere- but that would most likely be evidenced by having lower levels most often..
You may want to adjust your throttle control cable, is all.
Quick Reply: truck jumps when going from park to drive
