OEM remote starter no longer works!
Old Jul 19, 2013 | 09:55 AM
Izero's Avatar
Izero
You have to give the guy some time, he gets a ton of PMs and E-mails, he'll get to you no worries.
Old Jul 19, 2013 | 03:23 PM
DodgeCACares's Avatar
DodgeCACares
Originally Posted by Mike649
The local dealership had the truck in today for the remote start. They attempted to solve the problem but couldnt find what the problem is. They said its an older version remote start and they no longer have schematics to diagnosis it. Seems like bull****, but at leasy they didnt charge me.
At this point I could try taking it to another dealer for a second opinion. I thought paying the big bucks for a oem remote starter would eliminate an issue like this. Guess I shouldve went aftermarket!
Anyone know how to diagnois this?
Mike,
Sorry to hear about your concerns. If you'd like additional assistance reviewing the concern, I can look into this further with your servicing dealer. Please PM me the name of your dealer and your VIN#, I'd be happy to help.
Old Jul 20, 2013 | 01:06 AM
Mike649's Avatar
Mike649
Ok thanks for the heads up!
Originally Posted by DodgeCACares
Mike,
Sounds great, thank you!
Old Jul 24, 2013 | 09:12 AM
Mike649's Avatar
Mike649
New symptoms, after pressing starter button the truck now beeps a few times and the lights flash. Still didn't start...
Old Jul 24, 2013 | 01:02 PM
Izero's Avatar
Izero
Still sounds like an electrical problem with the sentry system somewhere.... those problems can be very difficult to locate.... a lot of tracing wires is required.....
The dealership should be able to help if you find them all of the data, has DodgeCares helped you at all?
Old Jul 24, 2013 | 02:08 PM
Mike649's Avatar
Mike649
I haven't heard anything from dodgecares. Dodgecaresca wasn't able to help.
Old Sep 26, 2013 | 07:27 PM
nickb86's Avatar
nickb86
Default remote starter fix?
I had the same issue, I ended up disconnecting it from the ignition and then reconnecting it. That got the light to come on, but still did not start. It alerted to a hood switch/brake switch issue. The dealer wanted $90 to diagnose it. I checked the ground coming from the starter and that was my problem. Im not sure why, all it did was disconnect the ground and attempted to start the car, as expected it did not start. I did this a few times until the security light came on. After that I reconnected the ground and attempted another start with the remote starter. And what do you know it started right up on the first time without a problem.
Old Sep 27, 2013 | 11:51 AM
Izero's Avatar
Izero
Hood Pin Switch or starter ground are definitely possible causes. thanks for posting. Hopefully the OP sees this.
Old Sep 28, 2013 | 08:02 PM
Mike649's Avatar
Mike649
Thank you for sharing your experience. I will have to look at that, maybe I can get lucky as well. Winter is coming,quickly and it sure would be nice to use my remote start!
that dodgecares member never did respond.
Old Sep 30, 2013 | 09:02 AM
Izero's Avatar
Izero
You can always e-mail dodgecares at:
dodgecares@gmail.com
He gets a lot of e-mails so be patient.
