Brake lights not working
Old Jul 14, 2013 | 11:00 AM
willmanuele's Avatar
willmanuele
Default Brake lights not working
whats going everyone. I have a 03 dodge ram 1500 was wondering if anyone had any pointers. no back brake lights changed tail light boards and changed the brake light switch and still don't have anything.
Old Jul 14, 2013 | 11:27 AM
abarmby's Avatar
abarmby
Search on here for PDC problems.
The Power distribution Center develops over time, corrosion on the internal printed circuit boards. This causes high resistance/open circuit conditions that stop the FCM (Front Control Module) from switching on stuff such as head lights, rear lights and particularly the park lamps. Plus, other more weird stuff.
If all your bulbs, fuses, and wiring are OK, I'd bet it's that.
Al.
Old Jul 14, 2013 | 11:45 AM
Gone Fishin's Avatar
Gone Fishin
Yup,
What Al said
Old Jul 14, 2013 | 01:29 PM
willmanuele
where is the Front Control Module located at?
Old Jul 14, 2013 | 02:51 PM
abarmby's Avatar
abarmby
It's a module that's attached to the side of the PDC.
It has 4 screws bolting it on.
Remove those and then pull the module away from the PDC.
Disconnect the battery first.
There's a large plug on the back of it which fits into its partner on the PDC.
Al.
Old Jul 15, 2013 | 12:46 AM
willmanuele
Would the other name be multi-function switch or no?
Old Jul 15, 2013 | 01:29 AM
KasperR34's Avatar
KasperR34
Old Jul 15, 2013 | 09:46 AM
abarmby's Avatar
abarmby
No.
The multi function switch is the main lights switch in the cab, that turns the park, heads, and the fogs on.
The FCM is an electronic module as stated earlier, that bolts to the side of the PDC.
Al.
