Can I tow a 7000lbs Travel Trailer?
Old 07-21-2013, 08:43 PM
haus.williams's Avatar
haus.williams
haus.williams is offline
Exclamation Can I tow a 7000lbs Travel Trailer?
2006 1500 Dodge 4x4 Mega Cab Hemi 5.77 with 3.73 gears tires 285/70R17
Im buying a new travel Trailer that the dry weight is 6950lbs. Will I be ok? i need any suggestion or knowledge you may want too share
I know that the Mega cab 1500 is almost a 2500 but I need more info
Dodge web site says i can tow 7300 but i also hear Dodge under shoots their ability
Old 07-24-2013, 11:33 PM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
Dodge Forum Moderator
Welcome to DF.
The early Mega Cabs like yours do indeed have 2500 axles. I do indeed hope you can tow 7300 lbs... my little Dakota (with trailer tow package) is rated to tow about 6800 lbs.
For future reference:
https://dodgeforum.com/forum/dodge-r...ead-first.html
I will move you to the correct section now.
Old 07-25-2013, 05:07 AM
08HEMI1500's Avatar
08HEMI1500
08HEMI1500 is offline
Yep my regular half ton 1500 is rated for over 8k lbs. So you can definitely tow more than that with a Mega. Although 4x4 does lower the rating by a couple hundred pounds. But yes you will be fine as long as you aren't loading another vehicle onto the trailer
Old 07-25-2013, 11:09 PM
haus.williams
Not loading a vehicle hauling 35' travel trailer @ 6950lbs
I pulled it home yesterday and didn't know all tanks were full of water and it pulled ok. I empties all tanks and will tow tomorrow about 100 miles. Dodge says it will tow 7400
Old 07-25-2013, 11:48 PM
08HEMI1500's Avatar
08HEMI1500
Yea I just looked it up. Hmm that's weird because you'd think it would be higher then the regular 1500s since mine is rated at 8750. I guess it has to due with the weight of the vehicle since a Mega is alot heavier and it's still classified as a 1500 due to the leaf springs so that brings the rating down. Either way you're still good. Just don't get pulled over if you go over
Old 07-26-2013, 08:39 AM
haus.williams
What I have found is its only 50lb lighter than the 2500. I'm going to add some helper springs and may go with 5/10 gears, this should solve any problems at least until I go get a 2500 with a Cummings
Old 07-26-2013, 02:09 PM
p38251's Avatar
p38251
p38251 is offline
5.10 way to much gear IMO. I had the same size tires on a 1500. I ran 4.56 gears
Old 07-26-2013, 09:53 PM
08HEMI1500's Avatar
08HEMI1500
Can you even get 5.10 gears for our trucks? I thought the highest was 4.88s and that's for 2WD only
Old 07-26-2013, 09:57 PM
p38251's Avatar
p38251
p38251 is offline
4.88 for 2wd. 4.56 is as high or low you can go in the front diff. I believe he will have 2500 axles. 5.10 I think will be too much, with the tires hes running.
Old 07-26-2013, 10:08 PM
08HEMI1500's Avatar
08HEMI1500
I know he has 2500 axles but I still didn't know you could go that low. Never seen anyone do it.
Quick Reply: Can I tow a 7000lbs Travel Trailer?
