3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Would have to check leaf spring spacing, track width and since the 2nd gen has rear drums and the 3rd gen discs, your braking bias would be all kinds off, requiring an adjustable proportioning valve.
The 9.25 is still being used today. The only differences are in the spring perches on the axle housing. The 2nd gen Rams had a narrower spring spacing than the 3rd gen. The rear brakes are also different as the 2nd gen uses drum brakes and the 3rd gen is disc brake.
