Last edit by: IB Advertising
Browse all: Lighting Guides
- Dodge Ram 2002-2008: Why Aren't My Trailer Lights Working?
Guide to diagnose trouble and recommended solutions
04 Ram electric problem brake lights for trailer
Hello,
my left rear brake light for the trailer does not work but the left brake light on the truck does work...
I have trailer towing package.. both the 4 pin and 7 pin has the same problem. and both trailer brake light fuses are good on the truck.
I have had little luck finding a wiring diagram for my 04 .. mainly for the trailer towing option
the right brake light does work on truck and trailer. as does the turn signal.
Help.
Help.
No voltage at 4 pin or 7 pin for left brake light. but right is OK.
I am a retired auto mechanic, I do know something about wiring .. but without a wiring diagram. I am getting no where.
the voltage was tested with AND without trailer connected.
I guess I should add.. I got truck NEW... never had a trailer connected to truck.
04 Ram 1500 2 wheel drive, V6 5 speed manual, 355 true-loc. trailer towing package. 39,000 miles and never wrecked or had electrical trouble.
I do not think that will work,
the head lights are controlled by the computer. so removing the battery cable the computer will shutdown and NOT turn on the head light circuit.
but I did disconnect the battery cable and it was OFF overnight.. just because it was late,
No help. I cut all light wires to trailer under truck, and removed 3 fuses from fuse box, trailer left and trailer right and trailer park lamp.
install powered coupler. I am now good to go.
Trending Topics
