A/C Problems please help
Old Aug 20, 2013 | 08:12 PM
Denniss66's Avatar
Denniss66
Default A/C Problems please help
I have an 07 cummins with a 5.9L my air conditioner has recently stopped on one of the hottest weeks we have had all summer. I checked fuses they are good. A/C turns by hand. I figured it needed a recharge so I got the kit and when I hooked it up gauge shot to max. Any ideas on what my problem could be would be greatly appreciated thanks.
Old Aug 20, 2013 | 09:09 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Does it work when driving but not when parked or stopped at a light? Or not at all?
Old Aug 20, 2013 | 09:16 PM
Denniss66's Avatar
Denniss66
Doesn't work at all not even when defrost is on. Seems like clutch fan grabs when I got the ac button on like it should but ac won't kick in.
Old Aug 20, 2013 | 10:49 PM
itsUhHemi's Avatar
itsUhHemi
What do you mean by "shot to max?" Because having TOO much freon in your compressor can damage it.
Old Aug 21, 2013 | 05:50 AM
Gone Fishin's Avatar
Gone Fishin
It might be a good start to check for any DTC's. There are sensors such as the evap temp sensor, if it went bad would prevent the system from energizing the clutch for the compressor.
If it has that much pressure initially, most likely there isn't a Freon problem, at least in part.
Honestly, if you don't have any idea how the system is designed to work and/or have access to a FSM for the truck, you might be ahead taking it to a shop to at least diagnose the problem. It could be something as simple as a bad relay in the FCM (fuse box) under the hood. Try changing any two of them out for the compressor relay (they're all the same relays)
Old Aug 21, 2013 | 12:05 PM
itsUhHemi's Avatar
itsUhHemi
Don't think he has any codes present. It's probably either your clutch cycle switch, lo-side pressure switch, or your a/c clutch relay.
Old Aug 21, 2013 | 03:13 PM
Denniss66's Avatar
Denniss66
I had a code p0483 reduced fan speed or something like that othere
Than that no codes I couldn't find any relays in fuce box and there wasn't many fuses in there I checked them all and they were good ill check wires on ac tomorrow cause I was working on water pump .maybe I broke a wire or something.
Old Aug 22, 2013 | 12:54 PM
Denniss66's Avatar
Denniss66
Figured out the problem the clutch is wrecked on the ac
Old Aug 23, 2013 | 01:50 PM
Denniss66's Avatar
Denniss66
Does anybody know if you can order just the clutch for these things or do you have to get a whole new assembly
Old Aug 23, 2013 | 02:21 PM
1ATony's Avatar
1ATony
Former Vendor
We don't carry AC parts here, I just went through this on my 97 Grand Cherokee. I found a brand new OE assembly on EBay for like 100 bucks. It works awesome.
Tony
