How do i fix loss of power
Old Aug 25, 2013 | 09:05 AM
joe_turnock's Avatar
joe_turnock
Default How do i fix loss of power
I have a 2002 dodge ram 1500 with a 4.7 liter and just recently i had the timing chain replaced had good power i have no power now i also have an engine light on for EVAP could this be my loss of power
Old Aug 25, 2013 | 05:19 PM
Welcome to DF. Moving this to the 3rd gen Ram section.
Old Aug 25, 2013 | 08:26 PM
TRO14's Avatar
TRO14
What code do you have?
Old Aug 26, 2013 | 12:28 AM
KasperR34's Avatar
KasperR34
I bolded your problem.
Sell it and buy a Hemi
Old Aug 26, 2013 | 08:22 AM
p38251's Avatar
p38251
Evap won't cause that. However if whoever did the timing chain is off a tooth that may. Why was the chain replaced?
Old Aug 26, 2013 | 07:46 PM
joe_turnock
The timing chain was loose and stretched out
Old Aug 26, 2013 | 07:49 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Make sure the PCM memory gets wiped. Get a cam/crank relearn done with a scan tool. When they're in there ask them to look at the Cam/Crank degree difference in the PCM data.
Which EVAP code is it?
Old Aug 27, 2013 | 02:10 AM
daksnbeers's Avatar
daksnbeers
Ha. Loved the delivery on that.
Old Aug 29, 2013 | 02:47 PM
ThisIsChallenging's Avatar
ThisIsChallenging
You can also reset the computer but unhooking the battery for a few minutes...unless you have a hand scanner, then you can just clear codes and see if they come back.
It's probably worth it to get buy a hand scanner too btw, I use mine a lot and you can get them cheap.
http://www.amazon.com/s/ref=nb_sb_ss...tomotive%2C104
