a/c control switch
Old Aug 27, 2013 | 09:02 AM
kevin-clarke's Avatar
kevin-clarke
Default a/c control switch
I have cold a/c blowing very slowly, fan speed changer works, cold to hot switch works, but when i move my control switch to various selections, the air doesnt change. meaning, my air blows through the front vents but wont change to defrost, floor vents or anything. It also seems to only bring in outside air (when i'm behind a car with bad exhaust, i smell i terribly). Does this sound like a switch problem, or a recirc door issue?
Old Aug 27, 2013 | 03:10 PM
abarmby's Avatar
abarmby
Recirc unfortunately.
Old Aug 27, 2013 | 03:31 PM
DodgeCares's Avatar
DodgeCares
^^ probably
What year?
Old Aug 28, 2013 | 09:08 AM
kevin-clarke
it is a 2006
Old Aug 29, 2013 | 08:41 AM
uponone's Avatar
uponone
Sounds like your recirc door AND the door which directs the air from floor to dash to defrost. Your recirc door you can mess with without taking the dash off...the other door you'll have to pull the dash and the whole HVAC box to get at. I already went through this...twice. (once to change a leaky heater core, then again to change the doors). If you can live with just the dash vents working thats fine...but I needed defrost for cold winters/rainy summer days.
Old Aug 29, 2013 | 10:45 AM
abarmby's Avatar
abarmby
Kevin-clarke.
Try this. This is the way I'm going for my door issues.
There's videos on "how to's" diagnosing which doors are defective and how to replace them. Plus parts which you can buy to effect the repair.
http://www.heatertreater.net/?gclid=...FfIPtAod0BcAGw
Al.
Old Aug 29, 2013 | 12:10 PM
LoneWolfArcher's Avatar
LoneWolfArcher
When was the last time you changed you PCV valve? SOunds strange right?
Last week drove my truck, air worked great, but at night when it cooled off when I tried to run defrosters, vents at windshield wouldn't blow. All other settings worked but not defrost. Read a thread on here and a guy said he was having problems like this and fixed it by changing his PCV valve.
Monday I stop at O'Reilly's, get the last PCV valve they have in stock. An off brand $1.99 model. Pop my old one out and the thing is nasty, looks like the original! (Maybe it wasn't but it was bad.) Pop new one in, get in truck, turn on defroster: BAM! It works.
Old Aug 29, 2013 | 01:26 PM
abarmby's Avatar
abarmby
I call red herring (B.S) on that one. No way the PCV valve is associated with control of the venting system in these trucks????
Al.
Old Aug 29, 2013 | 01:56 PM
LoneWolfArcher
Al.
Maybe not in a 3rd gen. But in my 2nd gen it absolutely did.
See:
https://dodgeforum.com/forum/2nd-gen...ild-vents.html
Old Aug 29, 2013 | 02:35 PM
abarmby's Avatar
abarmby
Hmmmmmmm
Sorry.... Your right. I Could only reference this to the third gen.
