Brakemotive install
Brakemotive install
Hey everyone. So I ordered the Brakemotive set off ebay and it's here (fast shipping) and I'm gonna do the install when I go home in December (kinda hard to do it in my apartment complex parking lot). I was just wondering for those of you that have these brakes, what do I need for the install tool wise? I know I need some floor jacks since I own none but what else? I'm going to be collecting the tools I need over the next couple months so I want to know head of time what to get. Also any install tips or a write up would be awesome as well. Thanks guys!
Change all 4 rotors and pads in an hour? You are a far far far superior mechanic to me if you can do this in an hour in your driveway, or anywhere for that matter. Those rotors are a pita to get off if they haven't been off recently.
08, I put that set on my truck, straightforward as far as should be the same as any brake set. If you are indeed doing all rotors and pads as I assume, and your rotors haven't been off in a while, this trick worked pretty well for me.
Basically you use a couple bolts in where the pads bolt in and the pressure of that to push the rotors off. My fronts I got off with a couple whacks then I used that trick to get the rears off.
On a side note, I hope you got a good deal, brakemotive gives a discount to members on the forum, like another 10% off, I paid 210 for drilled and slotted rotors and ceramic pads shipped to my door (all 4). Good luck with the install, you will be fine.
Trending Topics
Remove Rusted Brake Rotors ( Easy for any car or truck ) - YouTube
And TRO14 I wouldn't waste my time doing just fronts or rears. Might as well do all 4 especially when there are deals like the Brakemotives
