wiring identification/purpose
Old Oct 1, 2013 | 09:02 PM
les.little's Avatar
les.little
Default wiring identification/purpose
Hi, newby to this forum. Recently bought a 2008 dodge ram 1500 quadcab. been getting to know my truck and learn as much as I can about it. have found a unused wire with a connector that I can't figure out what it is for. i'm sure it for an option that I don't have but still would like to know what it goes to. it's a take off from the same wire line as the ambient temperature sensor wire on the drivers side grill area. it's a white/yl wire with a black wire. What does it go to? Thanks, I know you guys know the answer.
Attached Thumbnails wiring identification/purpose-thingybopper.jpg
Old Oct 1, 2013 | 09:58 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Post pics. Its the only way you are going to get an accurate answer
Old Feb 5, 2014 | 09:59 AM
dirtydog's Avatar
dirtydog
Moderate User
Foglight connection. Do you have fogs?
Old Feb 5, 2014 | 10:06 AM
Izero's Avatar
Izero
looks like the fog light harness connection.... if you don't have fog lights that would explain why it's just hanging out there...
Upside is you'd only need to get a new headlight switch w/ the fog option, the fog harness and the fog light assemblies to put fog lights on...
Old Feb 6, 2014 | 12:31 PM
lxman1's Avatar
lxman1
Site Moderator
My 08 has fog lights and no extra harness up there.
Old Feb 6, 2014 | 12:52 PM
Izero's Avatar
Izero
That's likely b/c it's already connected to that connector which prolly gets tucked away down there somewhere... Next time I'm under my truck (which might be tomorrow for an oil change) I'll try to remember to take a look at where the fog light harness goes.
