2007 Dodge Ram 1500-EVAP Engine Codes
Old Oct 16, 2013 | 04:23 PM
tony.sambuchi's Avatar
tony.sambuchi
Exclamation 2007 Dodge Ram 1500-EVAP Engine Codes
+++++++++ sorry if this thread needs to be moved to a different section ++++++++++ I just read the sticky!
Hello,
I have a 2007 Dodge Ram 1500. I am getting engine codes P0455, P0457 and P0456 with the GASCAP displaying on my dash. I was able to replace the gascap, cycle power, and I still have the codes. I was able to locate the evap canister near the gas tank and I dont see anything wrong with the hoses. The hoses that I can see look ok under the hood.
Ive watched every single video on youtube on this issues with no luck so far. ( haven't tried the cigar trick yet )
Im not sure where to locate the purge solenoid.. I cant seem to find a good diagram on the net where to locate parts on my truck.
Im willing to look further into this with the right advice!
Thank you,
Tony
Old Oct 16, 2013 | 08:51 PM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF. Will move you to the correct location.
For future reference:
https://dodgeforum.com/forum/dodge-r...ead-first.html
Old Oct 16, 2013 | 11:46 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Here is a TSB that may help you.
This bulletin is supplied as technical information only and is not an authorization for repair.
SUBJECT: DTC P0456 - Evaporative System Small Leak Due To Loose Charcoal From Canister
OVERVIEW: This bulletin involves performing the diagnostic procedure for DTC P0456, and if necessary, the replacement of evaporative system components.
MODELS:
2007 (DR/DH/D1/DC) Ram Truck (1500/2500/3500)
2007 (HB/HG) Durango/Aspen
2007 (WK) Grand Cherokee
2007 (XK) Commander
NOTE: This bulletin applies to vehicle built on or between January 26, 2007 and June 18, 2007 (MDH 0126XX to MDH 0618XX respectively).
SYMPTOM/CONDITION: The customer may experience a Malfunction Indicator Lamp (MIL) illumination. Additional investigation may reveal that the MIL is due to Diagnostic Trouble Code (DTC) P0456 - Evaporative System Small Leak.
DIAGNOSIS: 1. Was vehicle built (check vehicle build date) on or between January 26, 2007 (MDH 0126XX) and June 18, 2007 (MDH 0618XX)? a. If YES >>> then proceed to the next step. b. If NO >>> then STOP. This bulletin does not apply. Further diagnosis is required. 2. Using a Scan Tool (StarSCAN®) with the appropriate Diagnostic Procedures available in TechCONNECT > Service Info tab > 9 - Engine - Electrical Diagnosis > Diagnosis and Testing, verify all engine systems are functioning as designed. If DTC's other than those listed above are present record them on the repair order and repair as necessary before proceeding further with this bulletin. 3. Perform the complete Diagnostic Procedures for DTC P0456 - Evaporative System Small Leak.
NOTE: Make sure that the flow and smoke tests are performed completely.
NUMBER: 25-003-07
GROUP: Emissions
DATE: November 14, 2007
4. Was an evaporative system leak detected when a complete DTC P0456 Diagnostic Procedure was performed. a. If YES >>> then proceed to the next step. b. If NO >>> then perform the Repair Procedure. 5. Was the root cause of the leak in the evaporative system a leaking Evaporative System Integrity Module (ESIM)? a. If YES >>> then perform the Repair Procedure. b. If NO >>> then STOP. This bulletin does not apply. Further diagnosis and/or repair is required.
PARTS REQUIRED:
Qty. Part No. Description
IF HB/HG - DURANGO / ASPEN
1 52113549AE Canister, Fuel Vapor (includes: Seal and ESIM)
1 52855832AB Hose and Filter, Evap Fresh Air
IF WK/XK - GRAND CHEROKEE / COMMANDER
1 04891725AC Canister, Fuel Vapor (includes: Seal and ESIM) - All
1 52090315AI Assembly, Filler Hose (includes Evap Fresh Air Hose and Filter) - WK
1 52090241AD Assembly, Filler Hose (includes Evap Fresh Air Hose and Filter) - XK
IF DR - Ram Truck (1500) w/26 GALLON FUEL TANK
1 55398669AB Canister, Fuel Vapor (includes: Seal and ESIM)
1 55398232AA Hose, Evap Fresh Air
1 04891994AA Filter, Evap Fresh Air
IF DR - RAM TRUCK (1500) w/34 or 35 GALLON FUEL TANK
1 04891723AB Canister, Fuel Vapor (includes: Seal and ESIM)
1 55398159AA Hose, Evap Fresh Air
IF DH/D1/DC - 2500 or 3500
1 04891726AB Canister, Fuel Vapor (includes: Seal and ESIM) - All
1 52121718AB Hose, Evap Fresh Air - DH/D1
1 52121681AA Hose, Evap Fresh Air - DC
1 04891994AA Filter, Evap Fresh Air - All
25-003-07 -2-
SPECIAL TOOLS/EQUIPMENT REQUIRED:
8404A Evaporative Emissions Leak Detector (EELD)
8404-14 Service Port
8404-ADP Service Adapter - Filter Line
8404-UVL Ultraviolet (UV) Black Light
8404-CCL White Light
8404-20 Protective Yellow Goggles
8382 Gas Cap Adapter (1/4 turn cap)
6922 Gas Cap Adapter (Screw On Cap)
8399 Secondary Seal Depressor
REPAIR PROCEDURE: 1. Replace the following emission system components: a. Fuel Vapor Canister (with ESIM). b. Fresh Air Fuel Vapor Filter. c. Fresh Air Filter to Fuel Vapor Canister Hose. 2. Refer to TechCONNECT for detailed service procedures. From the “Service Info” tab select: 25 - Emissions > Evaporative Emissions > Switch - Evap System Monitor and Canister - Vapor
POLICY: Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
Labor Operation No: Description Amount
25-01-15-95 Fuel Vapor Canister, ESIM, Fresh Air Vapor Filter, and Fresh Air Vapor Hose - Replace (B) - DR / DH / D1 / DC
0.5 Hrs.
25-01-15-95 Fuel Vapor Canister, ESIM, Fresh Air Vapor Filter, and Fresh Air Vapor Hose - Replace (B) - HB / HG
1.2 Hrs.
25-01-15-95 Fuel Vapor Canister, ESIM, Fresh Air Vapor Filter, and Fresh Air Vapor Hose - Replace (B) - WK / XK
0.7 Hrs.
FAILURE CODE:
ZZ Service Action
-3- 25-003-07
Old Oct 17, 2013 | 07:53 AM
tony.sambuchi
Thank you master tech for your reply.
I checked the manufactures date on the drivers side door and found that it was manufactured in 6/12, MDH061222. I fit the bill for this bulletin.
Questions:
  • My truck is not under warranty. Would any of this be covered as a recall? Im not sure how these bulletins work.
  • Where is the purge valve solenoid on my truck? Ive seen people in videos verify these lines and also use one of these lines to do a DIY smoke test. I was able to find a shop to do this for $50 bucks.. not sure if im ready to fork over the $$$ yet.
  • I have a tool that can give me engine codes but this (Scan Tool StarSCAN®) sounds a little bit more advanced. Is this something AutoZone my have to use for free?
Any visual aids on a 2007 Dodge Ram would GREATLY be appreciated. Pointing out where the key components of the EVAP system. I will later post a video of all my findings to help support the forum.
Thank you everyone for your help in this matter.
Tony
Old Oct 17, 2013 | 10:26 AM
master tech
No its not a recall. TSB's are only just information for the techs that are having the same problem as anyone would have.
Old Oct 17, 2013 | 10:49 AM
tony.sambuchi
Ok, Thanks for the reply.
If someone could help with some diagrams/pictures of a 2007 Dodge Ram that would be great. Maybe some pointers with the smoke test. I plan on getting my hands dirty this weekend and would like to have all info I need soon.
Thanks
Old Oct 18, 2013 | 07:57 AM
tony.sambuchi
I called my local dealership and told them that there was a TSB on my truck. He told me he would take a look at it for free. The appointment is at 9:00 am today. Ill let you know what he finds.
Old Oct 18, 2013 | 12:41 PM
tony.sambuchi
Turned out it was a hose above the gas tank that was chewed up by my neighborhood squirrel. I now have another reason to hunt those darn things.
Two things to note about testing the EVAP system on this truck
  • In order to get to the tank you need to remove the drive shaft. The gas tank needs to shift over to the middle before it can be dropped down. You can suspend the tank with some bungee cord (make sure the tank is near empty)
  • If you want to do a smoke test you can do it with the hose that is going into the charcoal canister.
Old Oct 18, 2013 | 10:23 PM
master tech
Let me know when the BBQ will be. Don't use bungee cords. If anything use tow straps and yes on a next to empty tank. I normally use a bench and two 4x4 blocks and lower the vehicle down to the bench. Then remove the tank straps, and then raise the vehicle with gas tank still on the bench.
