Dodge Keyless Entry Remotes and Programming Instructions
Old Oct 7, 2005 | 08:44 PM
93Miata's Avatar
93Miata
Default Dodge Keyless Entry Remotes and Programming Instructions
What does your local dealer charge for Dodge keyless entry remotes?
My Dodge dealer wants $119 a piece plus $35 for programming for each of my cars (02 Ram pickup, 96 Intrepid)
I'm curious to see what other dealerships are charging for new remotes and programming.
I'm done with ebay because the listings show new remotes, and 3 out of 3 times I've won - I end up with junk that doesn't work and won't program. First one was superglued together and cracked. Can't check the battery if you can't even open it. Second one was completely corroded inside from water and didn't work. The 3rd one only 1 button worked and it looked like someone tried to superglue the circuit board pieces back together. Each one was advertised as new, or like new and they obviously weren't anywhere close to that. The Keyles Ride site is run by one of those same lying ebay sellers, so thats off the list too.
What does your local dealership charge? I bet there's some that want even more than what mine is charging.
Old Oct 10, 2005 | 10:15 AM
mill500's Avatar
mill500
Default RE: Dodge Keyless Entry Remotes and Programming Instructions
I'd be interested to know as well. I got a Mopar Sentry key and alarm system that I'm installing myself, but the computer needs re-programmed to acknowledge the Sentry key. Shouldn't be much--all they have to do is plug the DRBIII into the computer and re-flash it. Check out the TSB's on yours---if there's anything going on with your vehicle requiring the computer to be re-flashed under a TSB, they may do it NC if you have a good shop that you work with.
I've had pretty good luck with factory Mopar stuff. In most cases such as what I just got, the stuff just plugs in to existing harnesses--no fuss, no muss. There are a variety of web sites selling it. One I use most is Discountmopar.com. They usually have good prices, but it also doesn't hurt to check the dealer. As with alot of stuff on the web, once you pay freight you may not save much.
Old Oct 11, 2005 | 03:25 AM
Avanti's Avatar
Avanti
Yeah, ain't Ebay just great!
However, I suspect you will find the best prices from dealers who sell on-line (e.g. moparpartscenter.com). Can you not program them yourself, as with other manufacturer's? Sorry, I've no Mopar keyless entry vehicles at the moment.
Best of luck.
Old Oct 11, 2005 | 04:25 AM
FrankMcKeever's Avatar
FrankMcKeever
$119 sounds a little high to me..
Old Oct 15, 2005 | 12:10 AM
93Miata's Avatar
93Miata
I found another site online that I'm willing to give a shot - www.ThePartsYouNeed.com
The other KR site I mentioned before wants about $35 a piece with shipping for the 02 Ram remote.
They're about 1/2 that price on ThePartsYouNeed site with the instructions included. I ordered 1 this morning.
https://www.thepartsyouneed.com/disp...productId=1166
I'll keep you guys posted. If it works good, I'm going to order one for my 96 Intrepid as well.
Old Oct 19, 2005 | 02:45 AM
93Miata's Avatar
93Miata
I got my remote from ThePartsYouNeed.com in the mail today. 4 days isn't bad especially when one was a Sunday.
Programming was easy, took about 10 seconds. I can't believe a dealership would charge 1/2 hour of labor for a 10 second job. Thats a good way to lose customers.
Anyhow, the remote works great and when I went to put in an order for remote for the Intrepid I noticed I got free shipping, so I bought a 2nd remote for the Intrepid so I a pair for the each. FINALLY I will have remotes that work and that I can use.
ThePartsYouNeed.com rocks!
Old Oct 19, 2005 | 01:22 PM
osteodoc08's Avatar
osteodoc08
Thanks for the info. Always good to know.\
Glad everything worked out for you in the end.
Old Oct 19, 2005 | 09:34 PM
NDW13's Avatar
NDW13
We sell the one for the Ram for about $40....The one for the Intrepid is about $107. We program them for about $35-$40.
Old Oct 19, 2005 | 11:40 PM
93Miata's Avatar
93Miata
Picked up the Ram remote for $24.99 - https://www.thepartsyouneed.com/disp...productId=1166
The Intrepid remotes for $24.99 as well - https://www.thepartsyouneed.com/disp...productId=1196
Programming was free with the remotes.
Old Oct 21, 2005 | 02:47 AM
chipman0341's Avatar
chipman0341
I have a remote that needs programmed.
I was wanting to know if you could share the programming instructions so I don't have to go to the dealership and get ripped off.
