Radio Power Without Key
Old Dec 15, 2013 | 02:02 PM
AKCallahan's Avatar
AKCallahan
Default Radio Power Without Key
Ever since I bought my truck, the aftermarket radio turns off when I remove the key from the ignition. My 2006 Charger stays on for X amount of time so I wasn't sure if I could do something so my truck does the same
Old Dec 15, 2013 | 04:28 PM
Gone Fishin's Avatar
Gone Fishin
Actually, since you have the canbus communication bus, you may be able to. It would have to be turned on with a starscan tool at a dealer. I'm not absolutely sure it can be done, but I have heard of it. Best thing to do is call up a dealer or two and ask a tech that is well educated on the starscan tool if it is possible----Good Luck!
Old Dec 15, 2013 | 11:16 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
IMO, it would be more simple to just run a 12v wire to the radio and turn it off when you're done
Old Dec 16, 2013 | 12:47 PM
Izero's Avatar
Izero
yeah but then he'd need a diode to prevent backfeeding into the TIPM.......
Whoever installed the aftermarket radio in your truck did not use the Databus Interface harness, which is why it turns off as soon as you turn the truck off...
You need something like this:
http://www.metraonline.com/part/AX-ADBOX1
You can get a similar interface at a local Best Buy that has an Install Bay..... good luck.
Old Dec 16, 2013 | 02:22 PM
66three83's Avatar
66three83
I have a 2006 Mega Cab, and my stock radio shuts off when the truck shuts off. His aftermarket radio should do the same.
Old Dec 16, 2013 | 02:25 PM
66three83's Avatar
66three83
Izero, maybe the 2008 model is different. OP's truck is a 2006. I can tell you factually, the radio is supposed to turn off when the ignition is turned off.
Old Dec 16, 2013 | 02:39 PM
Izero's Avatar
Izero
I know in my 2008, the Radio will stay on when I turn my truck off until I open a door, or 10 minutes elapses...
Any vehicle with the CANBUS and TIPM should have the same setup.
I am 99% Sure that he is not retaining power when the key is removed because whoever installed the radio did not use the Databus Adapter when they installed the radio that he has in there now.
I've seen it a million times where customers of mine would come in wanting a cheaper install and then they'd come back a week later telling me there was a problem, then I'd show them the work order where I wrote that the customer did not want the suggested interface and I'd list the features that would no longer function properly.
GM's were the worst b/c that damn databus is hooked into everything.... (in some vehicles the On-Star voice wouldn't go through).... A real pain in the butt that was let me tell you.
I'm 99% sure (without looking at it myself) that, that is what the issue is.
Old Dec 16, 2013 | 06:03 PM
66three83's Avatar
66three83
Anyone else with a 2006 want to chime in? Does your stock radio stay powered up after ignition is turned off? Because ONCE AGAIN, my stock 2006 DOES NOT!!!
Old Dec 17, 2013 | 07:43 AM
rtmtrrdr's Avatar
rtmtrrdr
nope my 05 shuts off with the key
Old Dec 17, 2013 | 08:40 AM
Izero's Avatar
Izero
Check your owners manual.... As far as I remember nearly all of the newer Dodge trucks I've ever installed radios on with a Databus would stay on once turned off, and would stay on until a door was opened.
