Check engine light keeps coming back for O2 Sensor
Old Dec 20, 2013 | 10:39 AM
spf42c's Avatar
spf42c
Default Check engine light keeps coming back for O2 Sensor
Hello everyone,
First post, brand new to the forum. Just bought my Dodge Ram Quad cab 1500 4x4 about a month ago with 68k miles on it. I'm getting a little frustrated with this incessant check engine light/ O2 sensor code. It's been replaced twice already and each time the same code (bank 2, sensor 2 on the passenger side) comes back as the cause of the CEL. Is it a matter of resetting the computer a few times? Do I need to run higher octane fuel with fuel system cleaner through it to see if that helps? I'd really like to avoid the stealership. Any help is greatly appreciated. Thanks
Old Dec 20, 2013 | 12:06 PM
chuck_hammer's Avatar
chuck_hammer
have you checked for a broken/cracked wire for the sensor.. ?
Old Dec 20, 2013 | 12:28 PM
spf42c's Avatar
spf42c
I have. Everything checks out electrically.
Old Dec 20, 2013 | 01:57 PM
dirtydog's Avatar
dirtydog
Moderate User
Exhaust leak and/or bad Cat will cause codes too. Sensors aren't always the fix.
I would try to clean your EGR valve. If it's clogged you can throw a code as well.
Old Dec 20, 2013 | 03:31 PM
TRO14's Avatar
TRO14
What is the exact code you are getting? There is more than one code possible for that sensor. knowing the exact code would help narrow down what the issue is that is causing the CEL.
Old Dec 20, 2013 | 07:20 PM
r-g_richards's Avatar
r-g_richards
What brand of O2 sensors did you use. Ma's vehicle seem to like the oem NTK's and absolutely hate Bocshe.
Old Dec 20, 2013 | 07:31 PM
08RecordRam's Avatar
08RecordRam
yes bradn and exact code would help
most likely u may have a clog or comp doesnt like your sensor
have you tried completley resetting your comp then see if it comes on again.
also if your cats giving you problem u may smell a foul smell
Old Dec 20, 2013 | 09:46 PM
66three83's Avatar
66three83
Bosch have been known to cause errant CEL's
Old Dec 21, 2013 | 04:19 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
As Dirty Dog mentioned, a crack in the exhaust manifold or pipe as well as broken or loose exhaust manifold bolts will allow fresh air to get sucked in and mixed with the exhaust gas causing issues also
