Transmission reading
Old May 20, 2014 | 01:01 AM
ArmyRam's Avatar
ArmyRam
Default Transmission reading
I have a 2003 ram 1500. I ran the diagnostics on it Friday, & it came up with P0700 transmission control system (MIL reqest). What sensor do I need to replace.
Old May 20, 2014 | 03:10 AM
abarmby's Avatar
abarmby
P0700 is a generic code for a transmission failure.
Normally this codes is generated,when the transmission is placed in limp mode.
From memory either 2nd or 3rd gear is selected, to allow the vehicle to get home/off the freeway without damaging the transmission.
You need to use a star scan tool to get deeper into the diagnostics, to pull up whats wrong with your transmission.
Al.
Old May 20, 2014 | 02:30 PM
HemiLonestar's Avatar
HemiLonestar
Do you havea programmer? If not go to Autozone, they can pull all the codes. As abarmby said, p0700 is a generic trans fault. There should be at least one (if not more) specific codes to accompany it. Pray it isn't 0733 & 0734.
Old May 25, 2014 | 06:41 PM
ArmyRam's Avatar
ArmyRam
I changed the filter, & replaced the pressure sensor, ran the scanner again I received P0700, P0731, P0733, P0841, P0846, & P0876. I need to take my Truck into the shop now.
Old Jan 22, 2015 | 03:04 PM
dodgeprob1333's Avatar
dodgeprob1333
how do u fix the 0733 code
Old Jan 23, 2015 | 09:43 AM
HemiLonestar
0700 - general trans fault
0731 - Incorrect 1st Gear Ratio
0733 - Incorrect 3rd Gear Ratio
0841 - low range pressure switch rationality fault
0846 - 2-4 or 2C Pressure Switch Rationality
0876 - Transmission Fluid Pressure Switch rationality
You will always get 0700 when anything goes wrong with the trans. 0731/0733 sounds like a sensor is getting conflicting info. The last 3 I've never even heard of.
Old Jan 25, 2015 | 01:15 AM
lxman1's Avatar
lxman1
Site Moderator
If the filter o-ring didn't seat properly, it can suck air and cause low pressure and slippage. It is a common issue it seems.
Old Feb 1, 2015 | 04:15 AM
rought's Avatar
rought
sounds like the solenoid pack..2003's have issues with it.. there is an updated one for your truck. but you dont give us any info. like miles.. maintenance history.. ect..
