Advice please 2008 Dually
Old Dec 17, 2014 | 06:48 AM
ray bright's Avatar
ray bright
Default Advice please 2008 Dually
Hi
I live in the UK and have brought a 2008 Dually heavy duty to tow my 5th wheel.
This truck is overkill for the 5th wheel but it was the only truck available at the time apart from 1500 trucks.
The problem is this is a daily drive and the ride unloaded is not the best in the world, can anyone recommend what I can do to make this an easier daily drive but able to deal with the 5th wheel when needed?.
It was suggested taking out some leaf springs and fitting air bags but you are the guys to ask.
Thanks
Old Dec 17, 2014 | 08:31 AM
chuck_hammer's Avatar
chuck_hammer
I would first try.. lowering the air pressure in the tires.....
sometime 5 pounds can do a lot... and maybe 10 in the rears.... all 4 of them. when empty.
I am talking pounds per square inch... not the other units... you may need to convert.
Old Dec 18, 2014 | 04:55 AM
Gone Fishin's Avatar
Gone Fishin
I agree with Chuck, there is an "empty" tire pressure that should be run. I believe its on the drivers side door pillar. If I remember right I think its 40 psig, but not sure right now. Makes a huge difference.
Old Dec 20, 2014 | 06:58 AM
ray bright's Avatar
ray bright
I have let some air out and yes it has made a difference, simple but effective.
Would taking the overload spings make a difference or do these only come into play when it's loaded.
Thanks
Old Dec 20, 2014 | 08:58 AM
Gone Fishin
The overloads are only effective with a max weight load, if you aren't loading the bed often, the cheapest way to "soften" the load is to add weight, like sand tubes to the bed.
I do this in winter for mine due to the snow and highway driving, other than that, the only real remedy would be to remove leafs from the spring pack, or possibly looking into a progressive spring pack replacement. Check with a local brake and spring shop to see what they might be able to do. I tend to stay away from air bags personally because they tend to unload the suspension, rather than enhancing it.
You give these guys http://www.sdtrucksprings.com/leaf-s...f06c1562adb91d a call and see if they can do something for you
Old Dec 20, 2014 | 12:54 PM
scwpd's Avatar
scwpd
I've read a lot of people say adding the air bags to the back and running 5psi makes it ride a lot better I'm about to order some for my 1500
Old Dec 21, 2014 | 02:24 AM
Prismatic's Avatar
Prismatic
Ya'll bought trucks and want them to ride like benzos!
Old Dec 21, 2014 | 05:58 AM
Gone Fishin
Well sort of----really just not like ranch wagons, the dentist bill can be enormous when you gotta get your teeth glued back in.
