transmission for a 4.7 ram
Old Mar 22, 2015 | 08:34 PM
dadeo's Avatar
dadeo
Default transmission for a 4.7 ram
Having a problem with my tranny, curious on what are the possibilities....Was driving it last nite, stopped at a lite,when I went to go there was no response....Moving the shifter to park,drive then reverse and nothing happened. My truck being a 4x4, I switched it to 4wd auto,and got it moving that way,....Once I had it moving I switched back tp 2 hi made it home....Tried it again today and the same thing happened, HELP any ideas... thanks
Old Mar 22, 2015 | 11:37 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Hard to really go off of anything but clogged filter? Low fluid? Loose shifter? Burnt clutches? Blown pump? Stuck valve? Endless possibilities.
Do you have a check engine light on?
Old Mar 23, 2015 | 05:58 AM
dadeo's Avatar
dadeo
I check the level and it was ok, nd no the check engine light never came on.
Old Mar 23, 2015 | 04:50 PM
DodgeCares's Avatar
DodgeCares
Hi dadeo,
Sorry to hear about your concern. I recommend taking your vehicle to an FCA dealership for a formal diagnosis. Also, there is a TSB (21-021-08, screengrab attached below) that may apply to the issues you are experiencing, so I would bring this up to them as well. Whatever you decide, please keep us posted!
Old Mar 24, 2015 | 07:55 PM
dadeo's Avatar
dadeo
Default 4.7 transmission
well its at the tranny shop now, hopefully things won't be to bad...(fingers crossed) He made it sound like its not exactly the tranny but other things related to it.... find out tomorrow
Old Mar 26, 2015 | 06:16 PM
dadeo's Avatar
dadeo
Still at the shop,cant seem to find a problem when scanned. It acted up for the guybut then something slammed together underneath and has been able to drive it since.....No thanks, tearing it down ,trying to find any worn out parts...btw the fluid was full just alittle week, not metal shavings in the pan when they drained it.
Old Mar 27, 2015 | 09:58 AM
DodgeCares's Avatar
DodgeCares
Thanks for the update, dadeo. Please continue to keep us posted!
Old Mar 30, 2015 | 06:13 PM
dadeo's Avatar
dadeo
Default 4.7 tranny
Well, Good news / Bad news ------Good news my tranny is fine ......The bad news sounds like Im getting my transfer case overhauled...Sorry I cant be in more detail but Im a idiot when it comes to this stuff..
