changed broken valve spring now truck still runs rough
So by "real low" what is the number you're getting? Again I'd refer back to the intake manifold cracking as a possibility, possibly torqued down too much by someone if it was ever removed or removed while you did the valve springs or even if it was put on in cold weather below 32 degrees, the plastic intakes need to be room temp or the possibility of them breaking increases when torqued. SOHC Neon plastic Intakes can also crack when put on in cold weather, the symptoms of that were the engine idling at 5,000 Rpm right off the bat, but the crack in my intake was massive that caused that.
Check vacuum lines, check for high idle, check throttle body seal. After you check the easy stuff then check the cam related stuff. Its also possible the PCM is pulling timing causing the vacuum to be low. Don't tear the engine itself apart until you've exhausted all other options.
Well, I made my own smoke machine and found that I have a leak on the intake on the drivers side in the back corner. Now dealer says its on back order and "might" be able to get it in 2 weeks. Do any of you know of an aftermarket solution? Not goin for performance, my dad just needs it to be dependable.
Thanks to all of you for your help so far.
So after finally having a day off yesterday, I took the intake manifold off and found that one of the ports were melted almost all the way through (drivers side back corner). It took multiple calls to dealers to find a new one, apparently theres only 2 in the entire metro detroit area, and I got one. Cleaned everything up, installed new intake and fired it up. Ran like garbage. It idled but was very rough and seemed like timing was off. Found out the new intake is a revised version and theres a plug and clip to close egr port on top of intake. So when I put the smoke back on it, it was pouring out from this hole. It was too late to get the necessary plug and clip so I temporarily plugged hole and fired it up again. This time it wouldnt start without pushing the throttle and wouldnt idle without throttle. But, it ran better as if timing was ok. Put smoke machine on it again just to make sure of no leaks and it was all sealed. No codes but lightning bolt was flashing. Any suggestions from here?
Thank you
Thank you
