1500 CV axles problems with lift and 37's?
Old Apr 6, 2015 | 05:47 PM
Hjlancas86's Avatar
Hjlancas86
Default 1500 CV axles problems with lift and 37's?
Is anyone with a 6" lift on 37's having any problems with their front CV axles? I want to get 37's but some people said that the 37's will snap the axles….id like to hear some opinions. Also what would you recommends replacing when lifting a truck besides the tie rods?
Old Apr 7, 2015 | 04:44 PM
Hjlancas86's Avatar
Hjlancas86
158 views and no replies?
Old Apr 8, 2015 | 08:24 PM
Largefarva's Avatar
Largefarva
Never seen one break, just had a truck in with 37s, had 40k on it, no problems. Why are you wanting to replace tie rods? When doing a lift you don't need to replace anything other than what the lift kit calls for.
Old Apr 9, 2015 | 08:28 PM
Hjlancas86's Avatar
Hjlancas86
The stock tie rods seems like pencils to me and I figured they needed to be at least a little beefier since I'm going with 37's
Old Apr 10, 2015 | 10:05 PM
Largefarva's Avatar
Largefarva
Okay, well you won't be able to make them beefier without changing your steering knuckles, which probably will be required anyway with a 6" lift.
Old Apr 11, 2015 | 08:20 AM
HammerZ71's Avatar
HammerZ71
I've personally seen a CV fail catastrophically twice and in both cases the truck was running 37s (both Chevy, btw).
The added wight of the tire and rolling resistance alone add a good bit of stress, but the killer of CV shafts is the angle. Better lift kits replace components that help to maintain that stock angle whereas cheaper kits really increase that angle.
Old Apr 11, 2015 | 09:21 PM
Hjlancas86's Avatar
Hjlancas86
The kit I bought wasn't cheap by any means, $2200 but I very luckily found someone with the lift in the box that has never been taken out and I got it cheap. Heres what the lift includes:
Old Apr 11, 2015 | 09:44 PM
Hjlancas86's Avatar
Hjlancas86
This is what my lift consist of:
1. Replacement CNC machined steering knuckles yield best possible alignment specs.
2. Front lower control arm crossmembers laser cut from 3/16" material.
Belly pan, constructed of 1/4" material, connects crossmembers and protects differential.
3. (3) heavy duty cross members.
4. Torsion bar cross member brackets.
Old Apr 13, 2015 | 07:32 PM
Largefarva's Avatar
Largefarva
^I agree the angle of the shaft would be the killer more than the tire size. That looks like a good kit above....I've seen one before on a truck and it came with outer tie rod ends with a bigger stud.
Old Apr 13, 2015 | 08:20 PM
Hjlancas86's Avatar
Hjlancas86
i haven't taken anything out of the box yet but I will take a look this week. That would be great if it did, the only thing this kit doesn't come with is the skid plate which I can get one to fit so I'm not too worried about it. I guess we will see if the angle of the driveshaft is a big deal or not when I get it lifted soon. Its my first lift but have done some research for a while but still don't know everything. Learn something new every day
