Rusted out oil pan ???
Old Apr 17, 2015 | 02:13 PM
denvan's Avatar
denvan
Default Rusted out oil pan ???
2003 1500 5.7L 4x4
While I was under my truck trying to solve my O2 mystery, I discovered that my oil pan is so rusted out that oil is actually weeping thru the metal. You could stick your finger right thru the pan. I never heard of such a thing. I have a 1940 farmall with a pan as good as new. I had a 49 Buick and never had that happen. These new vehicles are junk!! If anyone else has had this happen please let me know. I suppose that will be a nightmare removing!!!
Old Apr 17, 2015 | 02:19 PM
I've heard of it happening on the 3rd gen Dakotas as well. Built to fail. Keeps car makers and parts manufacturers in business.
Old Apr 17, 2015 | 02:25 PM
p38251's Avatar
p38251
If you live up north, you can thank all that salt.
Old Apr 17, 2015 | 03:13 PM
chuck_hammer's Avatar
chuck_hammer
had that happen to a 10 year old 1977 Chevy Caprice ... so all the time...
you can not pick apples and oranges..
Farm equipment is better stuff.. its is designed to sit in a field....sometimes.
Old Apr 17, 2015 | 03:34 PM
Jeffs09's Avatar
Jeffs09
My neighbor is a mechanic and has replaced several oil pans on Hemi Rams. North Eastern Ohio, btw. Not all that uncommon. I've seen plenty of rotted rear diff covers on F-150's too.
Old Apr 17, 2015 | 04:56 PM
denvan's Avatar
denvan
Default How bad a job is it
How bad a job is it? I am not able to crawl under cars and trucks anymore so I have to rely on my helpers. Is this a backyard job? Will the pan drop straight down? Any steering or suspension linkage in the way? I would just like a heads up as to the difficulty factor before I recruit a helper.
Old Apr 24, 2015 | 08:27 PM
GreenEH's Avatar
GreenEH
I have an 03 hemi (although 2wd) and I was able to take the oil pan off without jacking the motor up. You will need a scraper of some sort to separate the gasket from the oil pan after removing all the bolts and tranny to engine stiffener. Make sure you remove just the oil pan and not the gasket as the gasket is one piece and is buried under the oil pick up tube. If it's stuck on the pan and you reef on it, you will break something! Oh, and the pan is a puzzle to pull off without lifting the motor; it literally "just" slips out. If you have trouble post back
Old Nov 26, 2016 | 11:51 PM
leothefox's Avatar
leothefox
I am replacing oil pan gasket cam off with a little twist to the side haven't put back yet will let u know
Old Nov 26, 2016 | 11:54 PM
leothefox's Avatar
leothefox
Remove oil pan had to remove gasket first came off with a little twist
