What is this sensor
Old Apr 27, 2015 | 10:20 AM
Northern Goat's Avatar
Northern Goat
Default What is this sensor
Hey Folks Decided to pop my TB off and give her a good cleaning. When I remove the top hat there is a plug that goes into it and there is some kind of sensor inside of it. What is that sensor and what does it do? 04 Hemi in case your wondering.
Old Apr 27, 2015 | 10:34 AM
Probably intake air temperature sensor. Post a picture.
Old Apr 27, 2015 | 07:29 PM
MikeHTally's Avatar
MikeHTally
Most likely the IAT. Make sure it's properly aligned when you put it back in.
Old Apr 28, 2015 | 08:56 AM
Northern Goat
Thanks Folks. What does the IAT do/control?
Old Apr 28, 2015 | 09:53 AM
SmokinJoe02's Avatar
SmokinJoe02
Tells the PCM how much fuel to throw at it. Hope you used non-chlorinated brake cleaner while cleaning it. It's a lot safer on the electronics that are close by. I'm about to do mine.
SJ03
Old Apr 28, 2015 | 10:29 AM
Senses intake air temperature to assist with fuel mixture control.
Old May 2, 2015 | 01:53 PM
dirtydog's Avatar
dirtydog
Moderate User
SJ03
Actually, you'd really want to use Throttle body cleaner. Even non-chlorinated brake cleaaner dissolves the protective coating that is on Throttlebody's which is why TB cleaner is recc'd.
Old May 3, 2015 | 03:27 PM
SmokinJoe02
Gotcha.
SJ03
