high beams with low beams
Old Sep 13, 2015 | 10:54 AM
4x4kingx889's Avatar
4x4kingx889
Default high beams with low beams
Hello what wire under the console can I splice to make my 03 highbeams stay on with lows? Now to be clear I have projector lights with 2 bulbs so heat wont be a issue and the low beams are HIDS on a relay harness and highbeams are LEDS so there will be no strain on the factory wireing It is a 03 by the way
Old Sep 13, 2015 | 11:45 AM
KasperR34's Avatar
KasperR34
Oh yes it will, I melted the plastic headlight housing in front of the projector for running too much HID. I would recommend adding fog lights or putting in 55w HID's there to combat the lack of light your projectors are putting out
Old Sep 13, 2015 | 11:51 AM
4x4kingx889
Only the low beams are HIDS the high beams Are LEDs and produce no heat at all
Old Sep 13, 2015 | 12:13 PM
HammerZ71's Avatar
HammerZ71
Problem is if you just short wires together they will both be on all the time your headlights are on.
You néed to do it with relays or better yet a pre-programmed relay like a Brite Box.
http://www.innovadd.com/bb.main.html
Old Sep 14, 2015 | 12:02 PM
HemiLonestar's Avatar
HemiLonestar
This is what I would recommend to keep from hacking up your harness and causing other issues down the road.
Old Sep 29, 2015 | 05:33 PM
4x4kingx889
does that keep the foglights on?
Old Sep 30, 2015 | 12:27 PM
TejasMtnBiker's Avatar
TejasMtnBiker
that would really be nice when towing my big boat at night thru the back roads so I could see better since im taking back roads to avoid the highway patrols dui check points
Old Oct 1, 2015 | 11:04 AM
HemiLonestar
Yes, this will allow you to keep highs, lows and fogs on at the same time. If you had an 06 or newer you can change a setting within the computer to do it. I just did this to my Charger not too long ago.
