temperature guage not getting to the middle
Old Sep 26, 2015 | 02:20 PM
Marchesani82's Avatar
Marchesani82
Default temperature guage not getting to the middle
hello guys. i have a 2002 dodge ram 1500 4x4 with 85,1xx miles. lately my temperature guage isn't reaching the center where it usually has sat all the time. I went ahead and changed out the thermostat thinking it was sticking open but that didn't fix it. I then went ahead and changed the engine coolant temperature sensor but that didn't help either. My radiator is 2 years old along with the water pump. Any suggestions would be great. I am the first and only owner of the truck.
Old Sep 27, 2015 | 09:44 AM
MikeHTally's Avatar
MikeHTally
Could be the gauge isn't happy. What value 'stat did you use? Do you have access to a ScanGauge or other device that will monitor the actual temp?
Old Sep 27, 2015 | 05:21 PM
Marchesani82
i got the thermostat from the dealer i believe its a 195 degree thermostat. I have a tuner i will have to see if its has the ability to monitor engine temperature
Old Sep 28, 2015 | 06:13 PM
MikeHTally's Avatar
MikeHTally
A 195 probably won't reach the center mark. My 203 settles right at the center mark. A 180 will be considerably lower (just over 1/3).
Old Sep 29, 2015 | 08:08 AM
HammerZ71's Avatar
HammerZ71
If it's from the dealer it's a 195*, should settle in right around 11 o'clock on the gauge...
Old Sep 30, 2015 | 07:30 PM
Marchesani82
I have attached a picture of where my needle settles AFTER my thermostat has opened. Maybe someone had put in a higher temperature thermostat and im not used to the needle being where it is now after i have replced it with a thermostat straight from the dodge dealer. I also replaced the coolant temperature sensor while i was there. Take a look at the image and let me know what you guys think. Thanks for all the responses, much appreciated.
Old Oct 1, 2015 | 07:00 AM
SmokinJoe02's Avatar
SmokinJoe02
looks normal to me.
SJ03
Old Oct 2, 2015 | 07:04 PM
MikeHTally's Avatar
MikeHTally
That's about where my 180 settled. My 203 settles half-a-needle below the center. My e-fan starts half-a-needle above the center.
Old Oct 8, 2015 | 06:40 PM
lxman1's Avatar
lxman1
Site Moderator
That is fine. Mine runs close to that. In the hot summer, It runs a little closer to the center. When there, my tuner shows it to be at 203* which is where it should be. In the cool/cold months, it runs about where yours is now.
Old Oct 14, 2015 | 12:14 PM
RamedHemi's Avatar
RamedHemi
That is normal and about where mine is as well. Sometimes it moves toward the middle but then back to around 11 o clock. My gauge was going way past the middle and that was the cause of a falling apart T Stat. Took out in pieces. Replaced all is good now.
