Turn on my A/C heat is on can't turn heat down
Hey everyone
Sweating my big butt off down here in Texas. Hope this is posted in correct spot. Forgive me if it isn't.
When I turn on my fan all I get is hot air, it's like my one of my duct doors are hung in wrong position on a valve isn't shutting. I turn on my a/c still hot air not as hot but hot air. I have tried every position from hi fan to low fan, turned thermostat cold to hot, worked every level from inside cab to defroster. Any advise from anyone would be great have a 8 hour ride into it 1 hour. Have tools with me, can anyone trouble shoot and advise you can text Eight1seven-three68-oneone42 thanks so much
The following users liked this post:
Jacob Hiller (11-08-2020)
Wished it was that simple but when temp is 75 degrees outside and turn on air and it is upwards towards 84+ even if it was out of vas would yet be that hot. Also I didn't have my air on. When I had it in it wasn't as hot but the heater will out perform the cold air anytime. Checked my frein level, besides the air worked great, and after a 4 hour sleep got up and cold front moved in and turned on heat, not for long never hit it to shut off. As day progressed I needed air but heater wouldn't switch over. Thanks though
