G2 Diff cover 9.25 rear fluid Capicity ? Who's running one?
Hi, I just installed a G2 Diff cover 9.25 rear Does anyone have this cover?what is the fluid Capacity ? G2 says 2.5-3 Qt but they also said it's not a extra capacity cover so I am not sure if I should add more as 2.5 Qt is only about a quart way up dip stick to the full line.
Ill call them again on Monday ( They are closed today ) but I figured Id ask if you guys knew.
http://g2axle.com/pages/view/torque
Ok, Because I see stock amount any where from 2.25 to 2.50 QT's, G2 said 2.5 to 3 Qt's and that it took same as stock but this cover Def looks deeper then stock. I just don't want to over fill it nor do i want to under fill it. I just don't know how accurate the dip stick is.
You guys using stock cover?
Several sites and differential builders prefer that the level be at the point where it comes out of the differential cover fill plug hole and that point is 2 quarts 16oz (or 2 1/2 quarts if you prefer) near exact at the spill out point of the stock 9.25 cover fill hole.
Not exactly sure how you'd get 3 quarts in there, mine was level and started to drip out of the fill hole at 2.5 quarts on both my 04 Hemi Ram and my 97 Ram.
I have a aftermarket cover with the fill on the top, I could probably fit another gallon if I wanted to.
Trending Topics
good catch
