2005 ram 1500 trans. problem?
Old Dec 4, 2015 | 06:11 PM
HDFatboy2000's Avatar
HDFatboy2000
Default 2005 ram 1500 trans. problem?
I have an 05 ram 1500 quad cab with over 184,000 miles. Lately I have had a problem with the rpms jumping up and down at 45mph. I'm turning around 1500 rpms then the rpms will jump up 500 rpms then back to 1500 rpms. I noticed that it gets worse in colder temperatures around 42 degreed and lower. Is the trany slipping or is the shift solenoid going bad? Any info would be appreciated.
Old Dec 4, 2015 | 07:49 PM
How's the fluid level/condition?
Old Dec 5, 2015 | 02:00 PM
HDFatboy2000
New fluid and filters and bands have been adjusted.
Old Dec 7, 2015 | 06:41 AM
SmokinJoe02's Avatar
SmokinJoe02
No bands to adjust on an RFE trans. I'd do a fuel system cleaning and/or tuneup.
SJ03
Old Dec 14, 2015 | 10:20 AM
HDFatboy2000
Ok SmokinJoe02 I'll do a fuel system cleaning and see hoe it goes. I guess my next question is where are the fuel filters located?
Old Dec 14, 2015 | 11:34 AM
SmokinJoe02
Shouldn't need to remove the filters. Just try this......
Go buy 3 bottles of Chevron Techron from AutoZone or Advance. Run your current tank of gas to 1/8 of a tank, pour 1 bottle in, fill with Super Unleaded to 1/4 of a tank, drive it like you stole it. Repeat with bottle #2, again fill with SU to 1/4 of tank, drive like you stole it. Add the 3rd bottle and fill with SU all the way up and drive it normal. You should be able to tell the difference now.
SJ03
Old Dec 14, 2015 | 04:32 PM
p38251's Avatar
p38251
No fuel filter. Screen in the tank.
Old Dec 14, 2015 | 05:22 PM
rtmtrrdr's Avatar
rtmtrrdr
When is the last time you changed your plugs/cleaned pvc valve/air filter ect.? mine was doing almost the same thing you are describing at about 110,000 miles.I changed everything and it fixed it
