Pulled my rear diff. cover..
Old Jul 5, 2016 | 08:35 PM
Thebigredtruck05's Avatar
Thebigredtruck05
Default Pulled my rear diff. cover..
Hey all! Due for a rear diff fluid change on my 05 Ram 1500 so thought id get to pulling it today.
It went well and my trucks all buttoned up now. But happened to find something a little odd, looks to be a piece of a cotter pin or maybe a sheared gear? Would like to get some opinions so I took a few pictures of the gears and the object I pulled. Let me know what you guys think!
Gears
More gears
Strange object
Old Jul 6, 2016 | 02:51 AM
Prismatic's Avatar
Prismatic
C clip?
Old Jul 7, 2016 | 04:37 AM
gerry92's Avatar
gerry92
The gears looks perfect fine to me.
Old Jul 8, 2016 | 11:04 AM
abarmby's Avatar
abarmby
You sir, are the unfortunate owner of a Dodge Ram with the infamous LSD retaining clip problem.
Contrary to what people mistakenly refer to as a "C clip"...... The correct term is retaining clip.
A C clip holds the axle shafts in place.
Now to continue with your problem, you must.....i repeat MUST remove the rest of the retaining clip which resides deep in your LSD clutch pack.
Failure to do this, WILL cause the remains of the damaged clip, to cut deep into the axle shaft bearings and the axle housing itself.
The bearings can be replaced, but if the axle housing is cut too deep with deep grooves cut by these clips in the soft metal, its a full axle replacement in its entirety.
So..... Open that sucker up again, do some research on this issue -there are many many threads on here about this- and pull out the rest of that damaged clip, inspecting the rest of them as you go.
If you have a silvery sparkling diff oil in there, your too late and the damaged clips have already started to cut into the diff housing.
You can run thousands of miles -i did over 20k - before i had enough saved up to install a Detroit TruTrac.
Pull all those clips out of the stock lsd and refill with fresh oil and friction modifier.
Then, save up for a DDT or Aurburn replacent lsd and forget all your trouble.
Dont forget, read up on here about this issue and good luck.
Please remember to post up whatever you do or find, so we can help further.
Al.
Old Jul 8, 2016 | 12:31 PM
HemiLonestar's Avatar
HemiLonestar
That's the start lol...be happy you caught it now.
Old Jul 8, 2016 | 07:51 PM
MikeHTally's Avatar
MikeHTally
Al.
What he said.
Old Jul 9, 2016 | 05:54 PM
stev's Avatar
stev
I'm new to this with an '03. Does the 3.73 rear axle have this issue? Or all of the rear axles have this issue?
Old Jul 10, 2016 | 12:43 AM
abarmby's Avatar
abarmby
They got things sorted by 05.
Made thd clips stronger I believe.
Old Jul 10, 2016 | 04:04 PM
Joe.G's Avatar
Joe.G
My Thread on the issue, Above info is correct be glad you caught it now, Is there any damage near the bearing cap's? Mine were worn in a bit but all seems well.
https://dodgeforum.com/forum/3rd-gen...nd-auburn.html
Old Jul 11, 2016 | 11:55 AM
HemiLonestar
This was an issue with the 9.25's in the 1500's. You have a 2500, you're good.
