Passenger window switch not working
Old Mar 23, 2017 | 06:35 PM
66three83's Avatar
66three83
Well done!
Old Mar 23, 2017 | 07:57 PM
Ron380's Avatar
Ron380
I hate it when that happens! Glad you got it.
Like I keep telling myself, Always start with the basics before you start throwing money at it.
Old Mar 24, 2017 | 08:11 PM
MikeHTally's Avatar
MikeHTally
Originally Posted by Joshh8120
But if I replaced the switch then the solder joints wouldn't be the problem, would it?
Depends on where the switch came from. Many posts on forums showing broken solder joints on replacement switches. Easier (and cheaper) to fix than replace.
Old Sep 9, 2021 | 03:09 PM
Fxguy72's Avatar
Fxguy72
Default Wire harness
I've got an 04 ram 4 door and the passenger switch randomly stopped working. I tried wiggling the wires like some suggested and got nothing. I read where some also said it could be a bad master switch so I replaced the switch and still nothing. I can roll every window up/down on the master switch and the rear window switches both work fine. It's only the passenger side switch that won't work. The door lock button works, but the window switch doesn't work and is not lit up. Any ideas?
might be the wire harness from the body to the door. I had the same problem with my 07 and pulled the rubber connector to the door and found five wires broken. Joined them back up and they all started working fine. I don't know if it is the same problem as yours but I found others that had the same problem and the same fix. Hope this helps you?
Old Oct 11, 2025 | 04:51 PM
savannah996's Avatar
savannah996
I have a 2003 regular cab where the passenger window switch has not worked for years. The truck only has 59K miles on it so its still in very good shape. Window works from DS and I have no window lock button. At the passenger side door jam connector the yellow power wire does NOT have power. I know if I supply power to it the window will work. So next I have to find out where the yellow wire goes inside the cab. I thought it would go back to the drivers side switch but it does not.
IT has to eventually go back to the window relay of which I believe there is only one for both windows. Anyone have this problem with a regular cab that could tell me where this yellow wire goes back to exactly?
Old Oct 11, 2025 | 10:19 PM
Yep, goes back to the drivers side switch, Connector 2, pin 8. Technically, its the 'window module', but, I believe that the drivers window switch is attached to it.....
Old Oct 11, 2025 | 10:29 PM
Fxguy72's Avatar
Fxguy72
Default Savannah996 check
Try the yellow wire to the window with a reliable ground. If the window goes up and or down then the wire is fine. Then it is a problem further down the line. Pick up a Hanes manual or the window wiring diagram. Go old school and manually trace the wiring backwards. Constantly check the window at each junction. It is a pain in the butt but it will lead you to the problem. Also check each union for corrosion. Sometimes the unions get funky and have to either be replaced or cleaned with a wire brush. After you clean them apply dielectric grease to both sides. Hope this helps?
Old Oct 11, 2025 | 11:12 PM
aleekat's Avatar
aleekat
I battled an intermittent passenger window for months. Master switch was the issue. Bought one from Switch Doctor, lifetime warranty.
Old Oct 11, 2025 | 11:23 PM
Fxguy72's Avatar
Fxguy72
That is one in a million. Before buying parts and trying to instantly fix it, it might be better to track down why it broke in the first place. For Savannah this might prove to be costly and time consuming. The fix you suggest might not work in this case and they would be out that money for the part and still have the same problem. The other side of this is someone could buy an electronic part install it and burn it out first try. Then they still have to find the problem and also buy another part to replace the part they just burned out. So my original suggestion to trace the wires back and test them along the way is a more responsible approach to fixing wiring problems to save money, time and frustration. Some parts take weeks to arrive and waiting that long to roll up a window before it rains is not plausible.
Old Oct 12, 2025 | 10:39 AM
An easy test would be to see if the yellow wire has voltage at the master switch.... if it does, then the break is between drivers and passengers door. If it doesn't, then it is quite likely a bad switch.
