Front end bang
Old Sep 7, 2017 | 12:55 PM
arff2108's Avatar
arff2108
Question Front end bang
First- I'm new to the forum so forgive me if I am bringing up a problem that has been discussed already. I've searched here and many other sites trying to figure out my truck issue.
Second-I've replaced all the parts I can think of. I have had the truck to a trusted shop twice and they say everything is tight and solid.
Third- the problem, I have a loud single bang (metal on metal) on the front of the truck that only happens when I pull out of driveway and turn wheel after truck has sat for at least a few hours. Doesn't matter if it is forward or reverse. Sounds like someone hitting fenderwell with a wrench or something binding then suddenly releasing the tension?(does that make sense). I've had many friends try to help find problem by having them look while I turn wheel and had them turn wheel while I look both on the ground and with the truck raised.
It is a 2005 quad cab 1500 2wd with 5.7 hemi. With 90,000 miles.
Old Sep 7, 2017 | 01:02 PM
Ball joints?
Old Sep 7, 2017 | 01:12 PM
arff2108's Avatar
arff2108
Everything have been replaced. Ball joints, tierods,shocks,rack and pinion,control arms etc etc.....
Old Sep 7, 2017 | 01:13 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
It's steering related. Try the box, shaft, and column
Old Sep 7, 2017 | 08:13 PM
TrueDogman's Avatar
TrueDogman
Sorry. Not familiar with 2wd models. Are they coil spring or torsion bar front suspension?
Old Sep 7, 2017 | 08:32 PM
arff2108's Avatar
arff2108
It has coil springs
Old Sep 8, 2017 | 07:39 AM
TrueDogman's Avatar
TrueDogman
Have a real good look for a broken spring. When they break they usually break a loop at the top or bottom. Top may be difficult to see
Old Sep 13, 2017 | 11:03 AM
66three83's Avatar
66three83
I had a bang, sounded like a backfire. Turned out to be the wheel bearing. It was binding, then releasing with a metallic bang.
