3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
FRiend bought a 02 1500 4wd with a broken lf cv axle(missing from vehicle) and then splines from the differential are stripped and part of the shaft is still in the hub bearing. So its not worth fixing the differential. So will the 2wd hub fit and or can the 4wd hub work without the cv axle instaled?
Dont know about 2wd hub. I dont believe 4wd hub will work without shaft. I believe large nut and shaft hold the bearing together. No nut and shaft...bearing hub assbly will come apart...
On an 02-08 (and probably beyond) 1500, 2wd and 4wd wheel hubs are the same, only differentiated by what type of ABS system installed in the truck (whether the sensor is there or not). Even the 2wd hub has splines in it. This is the specific hub for my 03 2wd.
