2007 Dodge Ram 1500 4x4 vibration
Old Nov 3, 2017 | 01:02 AM
Jason07ram's Avatar
Jason07ram
Default 2007 Dodge Ram 1500 4x4 vibration
My 07 Ram vibrates at around 55mph and up. It's really annoying and I'm not sure what is causing it. The vibration is felt in the seat and not the steering wheel. I've had the tires balanced even though the steering ejeel doesn't shake. It's pretty much stock except the leveling kit that's been on for about 2 years now. If anyone can help that would be awesome. I've taken it to a few shops and they can't find anything wrong with it...
Old Nov 3, 2017 | 10:13 AM
Did you also have the tires rotated? If not, that's next. Also check u-joins in the rear driveshaft.
Old Nov 3, 2017 | 10:24 AM
Jason07ram's Avatar
Jason07ram
Yes rotated the tires and replaced the u joints in the driveshaft and had the drift shaft balanced and still vibration
Old Nov 3, 2017 | 10:27 AM
Does it matter if you are on the gas or not?
Old Nov 5, 2017 | 11:09 PM
Jason07ram's Avatar
Jason07ram
Default No
No, just does it about 55mph and above.
Old Nov 6, 2017 | 09:54 AM
If you push the button for tow/haul, does the vibration change?
Old Nov 6, 2017 | 02:08 PM
Jason07ram's Avatar
Jason07ram
Yup I read about that and tried that didn't work and neither did loading the bed with weight.
Old Nov 6, 2017 | 03:06 PM
Gotta be something in the driveline then. Bad tire, bent driveshaft/axle, failing bearing......
Crawl under it, and check everything for any obvious signs of damage. Probably won't be that easy, but, it's worth a look.
Old Nov 6, 2017 | 04:35 PM
Jason07ram's Avatar
Jason07ram
I'll look again. When I looked a few weeks ago looked pretty normal and clean. Thinking maybe the front cv axle but just a guess.
Old Nov 6, 2017 | 04:38 PM
I would think you would feel that more thru the steering......
