545RFE will not shift out of park
Changed solenoid and filters now can’t shift out of park
Have a 2007 dodge ram 4.7 with the 545 rfe and I changed the solenoid block and filters now I’m unable to shift out of park I can’t figure out why. Did I somehow not lineup the valve body correctly with the shift linkage
I've got a similar problem going on and I just changed the solenoid block along with the transmission filters. I'm wondering / hoping I didn't seat the sump filter good enough and it needs to be reset. Once it warms up enough, I'll drop the pan again and check it out.
Anyone had success with sucking the transmission fluid out of the dipstick tube? If so, what did you use?
