36 gallon l tank
Old Dec 14, 2017 | 01:16 AM
Prairie Dog 51's Avatar
Prairie Dog 51
Default 36 gallon fuel tank
According to the vin decoder, my 07 1500 can have either a 24 gallon or a 36 gallon fuel tank. As it turns out, it has the 24. I pull a travel trailer and at 8 mpg, the 24 empties pretty quickly
I have located a 36 gallon tank, but my question is, will the sending unit, filler neck, etc. etc transfer directly to the larger tank, or will I have to replace the entire system?.
Old Dec 14, 2017 | 11:15 AM
Pretty good chance it's a direct swap. Look up part numbers for the fuel pump module, and see if it differentiates between tank sizes......
Old Dec 14, 2017 | 10:17 PM
HemiLonestar's Avatar
HemiLonestar
Yes. You'll need the one end strap for the bigger tank. The extra capacity is added at the front end (towards front of truck). Weedahoe did this swap.
Old Dec 15, 2017 | 12:42 AM
Prairie Dog 51
Lonestar,
So everything but the one strap will work on the larger tank?
Old Dec 18, 2017 | 11:29 AM
HemiLonestar
Not sure about the fuel pump, search through his posts, he did a write up on it.
