Problems with oil blowing back into intake.
Old 02-17-2018, 11:43 PM
ardodd's Avatar
ardodd
ardodd is offline
Originally Posted by 3rdgens4sell
Was just thinking about your problem. Might be worth pulling the valve cover and checking that the oil returns/drains for the heads arent plugged. It would be easy to check and not need a tester
Thank you sir, I will definitely pull the covers off again.
I removed them once already and checked the valve springs to see if it had any broken ones. But everything seemed fine.
Questions:
1) First noticeable problem: Oil blowing back into intake through the oil filler neck.
2)Second noticeable problem: After letting the engine run, then with it turned off. White/Gray smoke comes out of the inside of the engine.
Possible Problems:
1)Exhaust Gases not escaping. *Catalytic Converters Removed already*
a) Exhaust Valve(s) broke or bent or not sealing off. Old Valves may have been reused without grinding and resurfacing. The engine was rebuilt in Mexico, so I am not sure what they did now.
b) Piston Rings did not fully seat allowing the exhaust gases pass into block.
c) Exhaust Gases creating pressure inside of engine, which is forcing the oil to be blown out of engine through the oil filler neck. The PCV valve is a one-way valve and should only be allowing air (gas buildup) to return through intake.
Possible Test:
1) Compression Test on Cylinders
2) Remove Vent hose on Oil Filler Neck and for Compression coming from inside the engine.
3) ???? Any Suggestions ????
Solutions:
1) Hire a Lawyer to make them stand behind the engine Warranty.
2) Hire a local Mechanic Shop to pull and Rebuild the Engine. Then Hire a Lawyer to make them stand behind the Engine Warranty and pay for all cost.
3) Rebuild the Engine myself and take this as a learning experience.
Old 03-27-2020, 06:52 PM
XLV750LAURENT's Avatar
XLV750LAURENT
XLV750LAURENT is offline
Hi - did you fix your issue about oil blowing back into the manifold?
thanks
laurent
Old 12-24-2021, 01:17 PM
pruimann1's Avatar
pruimann1
pruimann1 is offline
thanks
laurent
I'm having this current issue now??? Any suggestions 2013 ram 1500 5.7 hemi SLT cold air intake
Old 12-24-2021, 04:56 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,276 Likes on 3,023 Posts
Catch can between the PCV port, and intake manifold.
Quick Reply: Problems with oil blowing back into intake.
