Po307 and po172
Old Mar 5, 2018 | 04:11 PM
gobeyus@hotmail.com's Avatar
gobeyus@hotmail.com
Default Po307 and po172
Ok i have a 04 ram 5.7 hemi i have a shudder at driving speed. Ive replaced 7 coil plugs wires injecters cam sens crank sens up strem 02 bank 1 map sens maf sens iat sens. It has a rough idle as well. Drive shaft u joints are good.all tires are true when you driving say at idle speed cruzing speed say 100klm you feel a slight shudder give it a bit of gas its shudders bad. Im mechanically incline been wrenching for thowsands of years but im stumped. Could it be valve springs
Old Mar 7, 2018 | 07:25 AM
You have addressed all the electrical components..... that leaves mechanical. Time to do a compression test I think.
Old Mar 7, 2018 | 11:09 AM
gobeyus@hotmail.com
Im assuming comp on the hemi is about 180 psi. I ordered a valve spring set im going to do them any way even if comp is normal the old girl has 380 thousand klm on her
